    How to make same diameter ?
    16 Posts 4 Posters 1.1k Views 4 Watching
    • cottyC
      cotty
      See this screencast...
      (I have to remeber to install the english version of SU 😕 )
      my SketchUp gallery
      • E
        erzane
        thanks for your reply
        -for the whole pipe
        I tryed to do the same as that video but I cannot succeed to rescale my pipe
        http://www.youtube.com/watch?v=eXh6y5b0pdg
        -about edit2:
        how did you do for having exact radius information of the circle ?
        I did ''right clic'' entity infos, but it don't gave me the radius
        because if I calculate radius with the TMT it rescale the pipe but still to be
        a difference between both each time I try
        p.s.
        -is curviloft free ?
        • cottyC
          cotty
          @erzane said:
          your link dosen't work
          pls see my edit
          The link works fine for me...
          To edit the radius, you have to select only the circle, not the face! (And it will only work if it is a "real" SU circle)
          my SketchUp gallery
          • E
            erzane
            pls see my edit
            p.s. if I mesure the radius with the TMT tool for the figure B = 2,04m
            the one of the figure A is 1,78m,
            so I rescale B, and it beginn 2,04 , so it's ok
            but when I mesure the A radius again, it beginn 2,34m ...
            very strange
            • cottyC
              cotty
              Curviloft is free, but you could (should?!) use the donate button if you find the plugin useful...
              my SketchUp gallery
              • E
                erzane
                ok, I see
                now I succeeded to rescale the ''circle''
                by changing infos of the radius on the entity windows
                so it's a first step 😆
                but for rescale the whole pipe
                it still doesn't work
                • cottyC
                  cotty
                  pls see my edit
                  very strange
                  Make shure that both pipes are in separate group and scale only one of them (while in edit mode of one of them)!
                  For other people it will be difficult to follow this topic if you change a lot in older posts, so it would be better to reply with a new post instead...
                  my SketchUp gallery
                  • E
                    erzane
                    ok I see
                    my two pipes weren't separates components
                    so that's certainly why the issue appears
                    edit:
                    now I created 2 components A & B
                    but it still don't work
                    • E
                      erzane
                      ok, I quote this time
                      so.. I succeeded to do it finally
                      the problem was that I had 2 components
                      (notion of ''group'' I never use it, only what I know about it it's that we can regroupe a number of components in one group, but don't know more about the subject. But perhaps now I have a different vision of it)
                      so I broke my B component and leaved only A as a component, like this the CPU recognized probabily A and B as 2 differents objects, that's why CPU didn't changed A after rescaling B this time.
                      is it correct ?
                      p.s. it's really difficult to measure the radius of 2 different sizes of circle precilely with the TMT. In my opinion the entity info (elementinformationen) is better for rescale anykind of circles based forms, by starting from an empty circle and adjusting after
                      • ely862meE
                        ely862me
                        You can rescale it directly .
                        [web 100%,396:1sqzi9pr]http://www.screenr.com/embed/JtRH[/web:1sqzi9pr]
                        Elisei (sketchupper)
                        Come and See EliseiDesign
                          Perhaps it would be easier to simply redraw one of the pipes so the diameters match? It's easy to get sucked into trying to repair something when the easier route would be to start over and do it right.
                          • E
                            erzane
                            DaveR
                            yes sometime that's the best solution as you say
                            Eli862,
                            pls whitch tool did you use on 0:32 sec ?
                              That's just the Move tool at :32.
                              • E
                                erzane
                                ok
                                I didn't know it can do that
