    [Plugin] UCS Manager
    34 Posts 10 Posters 12.9k Views 10 Watching
    • Didier BurD Offline
      Didier Bur
      This plugin is intended to provide SU users some basic tools to save, restore, delete and list their user coordinates systems (aka UCS) of the model.
      In SketchUp, you cannot save the axis systems you set with the axes tool, and obviously you cannot retrieve an axis system you used earlier or during another session. This extension offers an alternative method to avoid this.
      DBUR_UcsManager_v1_0_0.rbz
      Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=DBUR_UcsManager_v1_0_0
      DB
      • KrisidiousK Offline
        Krisidious
        Very kool making what should be a native tool come to life... Thanks Didier.
        By: Kristoff Rand
        • G Offline
          glro
          [attachment=1:1u8yr8v7]<!-- ia1 -->DBUR_UcsManager_v1_0_0.rbz<!-- ia1 -->[/attachment:1u8yr8v7]
          [attachment=0:1u8yr8v7]<!-- ia0 -->ucs_toolbar.jpg<!-- ia0 -->[/attachment:1u8yr8v7]
          nice idea
          but when i clic on the origin to register the SCU, the dialog box opens and it is not possible anymore to clic on the axes...
          to be honest, i did manage once... but it was luck of the beginner; i couldn't do it again...
            Didier Bur
            Hi Georges,
            When you register (save) an UCS, the only operation you have to do is to click at the origin of that UCS, no need to click on the 3 axes. As you can see, the cursor still have the correct orientation of XYZ axes. You'll only have to click the axes orientations when you restore a previously saved UCS.
            This is explained in the PDF doc included in the resources folder of the plugin. I've attached it here.
            Regards,
            UCS Manager.pdf
            DB
            • PixeroP Offline
              Pixero
              Thanks. Will be useful. 👍
              • G Offline
                glro
                @didier bur said:
                Hi Georges,
                Regards,
                i understand now; thank you
                maybe it would be useful to register automatically the UCS that comes by default with the sketchup model; otherwise you have to do it manually each time you create a new one
                the limit for the plugin seems to come from sketchup itself; for example, moving components with J FOLTZ's plugin mover2.rb, is according the original UCS, no matter which new UCS has been created and is active
                  Didier Bur
                  @Giro:
                  No, there's no need to do so, to reset the default axes, just right-click on an axis of your current UCS and select "Reset".
                  Regards,
                  DB
                  • G Offline
                    glro
                    @didier bur said:
                    @Giro:
                    Regards,
                    oh... i didn't know that
                    thank you
                    i add this information in my copy of your documentation
                    • EdsonE Offline
                      Edson
                      hi didier,
                      as simple to operatte as this plugin may seem to be, I am having trouble with it.
                      I have no problem saving the first custom axes position. but after the first it will not save any other. I am stuck with just one custom axes system.
                      I am probably doing something wrong. but what?
                      I use mac os x.
                      regards.
                      http://www.mahfuz.arq.br
                        Didier Bur
                        Hi Edson,
                        I suppose each time you register a new UCS you give it a unique name, right ?
                        Can you do this test: register 2 or 3 different UCS, then call the attributes manager to see if these UCS have been correctly stored as attribute dictionaries.
                        See attached image: in this example, I have registered 3 UCS named 11,12, and 13, so I have 3 attribute dictionaries named UCS_11, UCS_12, and UCS_13.
                        If that's no the case on your side, I'll have to further investigate what's wrong with the script on Mac.
                        Regards,
                        DB
                        • EdsonE Offline
                          Edson
                          didier,
                          I created three UCSs: 01, 02 and 03. then I clicked on List UCS and it shows only the first one (see below).
                          please. forgive my thickness but I do not know where is the Attributes Manager you mentioned. is there such a thing on mac?
                            Didier Bur
                            The attributes manager is an old thing by Google released in 2007. I have attached it here.
                            But the 'list UCS' command of my plugin retrieves the attribute dictionaries of your UCS and just displays them in another way. I see that your UCS aren't registered the way they should be 😞
                            Anyone on Mac encountered the same problem ?
                            I've tested the plugin on a Mac and it works OK.
                            Edson, can you send me a SKP with several registered UCS ?
                            DB
                            • EdsonE Offline
                              Edson
                              here you have a skp file with 5 UCSs registered, from 01 to 05. if you still want me to run the attributes thing, let me know.
                              you forgot to attach it.
                              UCS_Manager_test.skp
                                Didier Bur
                                @Edson:
                                I'm puzzled: there's only one UCS registered in you file. I've added 2 new UCS named 02 and 03 with no problem. I send you the file back, please check if they can be listed once back on your Mac.
                                P.S.: forget the attribute manager, the listing UCS command does the same job.
                                Regards,
                                DB
                                • EdsonE Offline
                                  Edson
                                  I am puzzled too. the UCSs you created are listed on my mac. however, I created UCS 04 and it did not register again.
                                  • G Offline
                                    gbu
                                    Hi Didier, will be very useful but have exactly the same problem on my mac- did you resolve? or is there an update for mac? Thanks
                                      I have updated this tool for Didier, now to be compatible from SketchUp v8 up to v2015.
                                      It will also now load from any suitably set up Plugins folder [in $:], rather than just the default Plugins folder...
                                      The latest version [1.0.0x] is in the PluginStore http://sketchucation.com/pluginstore?pln=DBUR_UcsManager_v1_0_0
                                        tommy.jhd
                                        Hello,
                                        TIG's update brought the following error:
                                        Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/DBUR_UcsManager/DBUR_UcsManager.rb
                                        uninitialized constant DBUR_Ucs::TRError Loading File DBUR_UcsManager.rb
                                        ...which I think is a similar error message to what happens when you try and load UCS manager from an alternate plugin folder.
                                        The standard v1.0.0 loads fine (from standard plugin folder)
                                        Is the solution obvious?
                                        I've been fiddling with Didier's ArcCircle+ rb, trying and failing to get it to work from an alternate pligin location. If UCS can be fixed, I'll attempt the equivalent on ArcCircle+ - and perhaps save you the bother.
                                        T
                                          @tommy.jhd said:
                                          Hello,
                                          T
                                          I'll check it out...
                                          Many of Didier's scripts do mess up if a non-standard Plugins folder is used...
                                          I thought I found all the culprits... maybe not.
                                            Here is an updated version.
                                            Please ensure that you have no other versions loading from other Plugins folder locations...
                                            • 1 / 2
