    Scene rename-missing dialog box
    7 Posts 3 Posters 693 Views 3 Watching
    • jojo9J
      jojo9
      i have a plugin (downloaded from ruby depot i believe) who states to rename scenes. Scenes are renamed always with prefix "scene" but thats not what i wanted.
      the script seems to use dialog boxes too, but i never got the choice to enter another scene name. Whats wrong?
      Here, the code:
      # mirale999 first release, with Thomthom's help.
      # Permission to use, copy, modify, and distribute this software for
      # any purpose and without fee is hereby granted
      # Freely use
      # Name               ;          Named_Scene.rb
      # Date               ;          v1.0 11/12/6
      # Description        ;          To Let you rename it upon adding a new scene
      # Menu Item          ;          View -> Add Named Scene
      # It works like this ;
      # Hit the hotkey or click the menu item, give you an inputbox, you can
      # choose to give the new a unique name, Or leave it to its default and
      # create like normal; Scene 1- Scene 2- Scene 3-...
      require 'sketchup.rb'
      module Named_Scene
        # Add menu items.
        unless file_loaded? File;;basename(__FILE__)
          add_separator_to_menu("View")
          UI.menu("View").add_item("Add Named Scene") { self.add_namedScene }
        @@scene_i = 1
        def self.add_namedScene
          model = Sketchup.active_model
          pages = model.pages
          # Ask user for page name.
          list = []
          prompts = ["Scene Name;"]
          defaults = ["Scene"+" "+"#{@@scene_i}" ]
          input = UI.inputbox( prompts, defaults, list, "Add Named Scene" )
          # Check if the user cancelled.
          return if input==false
          # Get data from result array
          scene_name = input
          @@scene_i = @@scene_i + 1
          status = pages.add( scene_name.to_s )
          file_loaded File;;basename(__FILE__)
      • TIGT
        Do you not get the input box saying 'Scene 1' etc?
        The code
        can be edited to say whatever default you want, perhaps
        "JoJo"+" "+"#{@@scene_i}"
        • jojo9J
          jojo9
          yes, it is a way. However, scenes situations change and the need to rename them differently too. So, i wanted a dynamic way to assign names, using a dialog box.
          Nice would be too, to have the option to rename only a part of scenes, like to rename scene 1 through 4 (of 10) with a given name, followed by a numeric value in one shot.
          • TIGT
            Look at smustard.com... I think there's a scene-renamer ?
            • jojo9J
              jojo9
              i got the plugin. I tried to:
              #1) rename tab 1 to tab 3 using the !-prefix, as the script explains.
              However, the scheme continues to extend the name convention of the first tab to all scenes, and ignores the ! in tag 4, were i wanted to start with another (the given) name scheme.
              #2) exclude tabs 4 through 10 == ex-and included scenes are renamed without distinction.
              Sum.
              Renaming with a custom name should be easy. And not via wildcards, special characters of any sort. Implicit, Intuitive methods are easy to forget and not valid for everybody.
              I'm not a 'friend' of message boxes, because they block the workflow, but sometimes they are fine. They are simple to invoke; plus renaming should help to organize and therefore limited to active scenes in my opinion.
              • renderizaR
                renderiza
                Hi, have you seen [Re]Scene? It can rename scenes and do other stuff as well. Here is link...
                http://sketchucation.com/forums/viewtopic.php?p=472206#p472206
                Also if you only want to rename just a few of your scene just uncheck "Include in animation" the ones that you don't want to rename. Hope this helps...cheers!
                [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                • TIGT
                  Thanks Renderiza...
                  I thought there was another tool - forgot about you 😳
                  I think yours will do what he wants...
                  PS: I have adjusted your PluginStore listing's description text to include the words 'rename' and 'reorder', so a search for scene rename will find it πŸ˜„
