    Where is Gamma Correction setting option?
    renderpluginsextensions
    3 Posts 2 Posters 3.4k Views 2 Watching
      Cveti
      Hello everybody,
      I posted a new topic, because I couldn't find an answer of my question - where is the setting for gamma correction? Using Sketchup Make 2013 and Vray demo downloaded from the vray website.
      I'm still following the vray for SU manual and I'm on the topic for Gamma correction. So, I want to set it 2.2 as given in the manual. They say that I can find the setting in Global Switches, but maybe this is valid for an old version of the render. Now it's not there or I can not see it...I don't know.
      Can yu help me please? I want to get more realistic image using Vray Sun and sky.
      Many, many thanks in advance!!!
      And very sorry for the very basic quest!
      • V Offline
        valerostudio
        I dont think gamma will give more realistic images but the setting is under color mapping and the default is already set to 2.2.
        Some suggestions for more realism -
        If you are using 1.6 beta then try a dome light with an HDRI image
        If you want to use Sky, then try changing the size of the sun in order to get softer shadows.
        Realism can only be achieved through detailed modeling, great materials, and interesting lighting.
        Good luck!
          Cveti
          Thank you very much for your reply!
          I found it and it's indeed 2.2.
          Thanks for the advice, too!!!
