    Set layer color with code possible?
    6 Posts 4 Posters 445 Views 4 Watching
    • renderizaR
      renderiza
      Hi, I want to be able to set the layer color with code but not sure if its even possible. Is there any way I can achieve this?
      Thanks!
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • T
        th3lurker
        Not possible as far i remember, i had the same question. But maybe things have changed.
        • jiminy-billy-bobJ
          jiminy-billy-bob
          Tig wrote a snipper for this : http://sketchucation.com/forums/viewtopic.php?t=21090
          But it only sets a RGB color. No material, no reading the color.
          It seems adam found a way to do it with the SDK : http://sketchucation.com/forums/viewtopic.php?f=180&t=25697
          Although he always forget to upload it ^^
          • renderizaR
            renderiza
            Thank you I will be checking them out!
            • TIGT
              Right now it's pretty messy... πŸ˜’
              There is nothing in the API.
              AdamB did say he found a way to do it using some C trickery, but it's never been made public.
              The way my cludge works is to export the layer in a DXF then rewrite its RGB values, then re-import it, overwriting the previous layer name and moving all entities to the new 'renamed' layer...
              This is frankly a poor do!
              Some of my tools that export DXF files [Slice(Pro)] do remap the layer colors to match some 'standards'...
              Since a DXF file is in plain-text it is easy enough to stream-edit that and adjust the colors RGB values after the export is completed...
              • renderizaR
                renderiza
                Hopefully next API update includes this function...Thanks TIG!
