    Face-tag number
    12 Posts 4 Posters 977 Views 4 Watching
    • pingpinkP Offline
      pingpink
      I'm working on face-tag number of similar faces to tag the same number on normal faces and change colours to see the different panel types , could anyone give me some ideas how to do this method as you can see in a picture ? I'm not quite good at programming. I have to do this before doing component mapping on faces.
      Tag Number on faces
      • renderizaR Offline
        renderiza
        Here is an attempt to pick faces that have same area size and paint them. It is limited to up to five different area size for faces but you can modify it to add more. Not sure if this is the way to go but at least is a starting point and if I find better way I will share it. Also this does not add the tag object on top of face at the moment.
        model = Sketchup.active_model
        @sel = model.selection
        ents = model.active_entities
        faces = ents.grep(Sketchup;;Face)
        @cw1 = []
        @cw2 = []
        @cw3 = []
        @cw4 = []
        @cw5 = []
        faces.each do |face|
            ## A ##
            if @cw1.first == nil
                if face.area.to_i != @cw2area and face.area.to_i != @cw3area and face.area.to_i != @cw4area and face.area.to_i != @cw5area
                    @cw1 << face
                    @cw1area = face.area.to_i
            if @cw2.first == nil
                if face.area.to_i != @cw1area and face.area.to_i != @cw3area and face.area.to_i != @cw4area and face.area.to_i != @cw5area
                    @cw2 << face
                    @cw2area = face.area.to_i
            if @cw3.first == nil
                if face.area.to_i != @cw1area and face.area.to_i != @cw2area and face.area.to_i != @cw4area and face.area.to_i != @cw5area
                    @cw3 << face
                    @cw3area = face.area.to_i
            if @cw4.first == nil
                if face.area.to_i != @cw1area and face.area.to_i != @cw2area and face.area.to_i != @cw3area and face.area.to_i != @cw5area
                    @cw4 << face
                    @cw4area = face.area.to_i
            if @cw5.first == nil
                if face.area.to_i != @cw1area and face.area.to_i != @cw2area and face.area.to_i != @cw3area and face.area.to_i != @cw4area
                    @cw5 << face
                    @cw5area = face.area.to_i
            ## B ##
            materials = model.materials
            if face.area.to_i == @cw1area
                @cw1 << face
                face.material = [255,0,0]
        	if face.area.to_i == @cw2area
                @cw2 << face
                face.material = [0,255,0]
        	if face.area.to_i == @cw3area
                 @cw3 << face
                 face.material = [0,0,255]
        	if face.area.to_i == @cw4area
                 @cw4 << face
                 face.material = [255,0,255]
        	if face.area.to_i == @cw5area
                 @cw5 << face
                 face.material = [255,255,0]
        If you have any questions or suggestion please let me know...cheers!
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
          renderiza
          @pingpink said:
          I noticed the same face area of the sloped faces and the upright faces , they have different colours.I don't know why it happens for this time , I will look later.
          Not sure myself why that is happening but will look into it.
          @pingpink said:
          I just tried to map components on coloured faces , but I have to select faces and a panel component together to place and copy on the faces.
          Not sure that I have to do the attribute's name on coloured faces to have the same names as component's names for component mapping.
          To avoid having to select coponents and faces manually maybe try adding the code below to the one on top. Note that you have to name the component definition name manually.
          components = ents.grep(Sketchup;;ComponentInstance)
          ## cw1 ##
          components.each do |component|
          	if component.definition.name == "cw1"
          		@sel.add component
          @sel.add @cw1
          ## Put code that place component copy to face here ##
          @sel.clear #Clears selection to select cw2
          ## cw2 ##
          	if component.definition.name == "cw2"
          		@sel.add component
          @sel.add @cw2
          @sel.clear
          ## cw3 ##
          	if component.definition.name == "cw3"
          		@sel.add component
          @sel.add @cw3
          @sel.clear
          ## cw4 ##
          	if component.definition.name == "cw4"
          		@sel.add component
          @sel.add @cw4
          @sel.clear
          ## cw5 ##
          	if component.definition.name == "cw5"
          		@sel.add component
          @sel.add @cw5
          Hope this helps and your plugin look very good from the video I saw...very impressive! πŸ‘
          • pingpinkP Offline
            pingpink
            Thank you kindly for your recommendation , it's my task to do facade modeling. I'm revising codes in each module now to make it better.
            I'm curious that Is there a way to do a code for copying different coloured panels and lay down on a base in the program ? For example , in a picture there are 2 different panels and I want to copy out. So, it can reduce a time of copying faces to draw patterns and convert to components, and then do mapping prototype panels back onto faces.
            Copy different panels to make a component later.
              renderiza
              Hi, here is one example on how to do what you mentioned. Add the following code bellow the one on top...
              @model = Sketchup.active_model
              @sel = @model.selection
              @ents = @model.active_entities
              if @cw1.first != nil
              	@sel.clear
              	cw1sample = @cw1.first
              	@sel.add cw1sample
              	cw1group = @ents.add_group(@sel)
              	tr1 = Geom;;Transformation.new([0, -300, 0])
              	instance = @ents.add_instance(cw1group.definition, tr1)
              	instance.transform!(tr1)
              if @cw2.first != nil
              	@sel.clear
              	cw2sample = @cw2.first
              	@sel.add cw2sample
              	cw2group = @ents.add_group(@sel)
              	tr1 = Geom;;Transformation.new([200, -300, 0])
              	instance = @ents.add_instance(cw2group.definition, tr1)
              if @cw3.first != nil
              	@sel.clear
              	cw3sample = @cw3.first
              	@sel.add cw3sample
              	cw3group = @ents.add_group(@sel)
              	tr1 = Geom;;Transformation.new([400, -300, 0])
              	instance = @ents.add_instance(cw3group.definition, tr1)
              if @cw4.first != nil
              	@sel.clear
              	cw4sample = @cw4.first
              	@sel.add cw4sample
              	cw4group = @ents.add_group(@sel)
              	tr1 = Geom;;Transformation.new([600, -300, 0])
              	instance = @ents.add_instance(cw4group.definition, tr1)
              if @cw5.first != nil
              	@sel.clear
              	cw5sample = @cw5.first
              	@sel.add cw5sample
              	cw5group = @ents.add_group(@sel)
              	tr1 = Geom;;Transformation.new([800, -300, 0])
              	instance = @ents.add_instance(cw5group.definition, tr1)
              I had to make face that you want to copy & move a group so at the end they are still groups. Not sure if you want to explode them back to lose face but I am sure there is a way to do that. Anyways hope this help...cheers!
              • pingpinkP Offline
                pingpink
                Thank you so much ! , The code is amazing to copy tag faces. The group result suits with my code to convert groups to components and create the center axis on the panel plane , but my code can do mapping components on faces only the component which is parallel to the floor, not vertical exactly copy from the model. So , I tried to rotate panels by this code :
                   #tr1 = Geom;;Transformation.new([0, -300, 0])
                   pt = [300,0,0]
                   v = Geom;;Vector3d.new(1,0,0) # The axis position to rotate opanel
                   tr1 = Geom;;Transformation.rotation(pt,v,-45.degrees)
                The code cannot be used properly if there is a slope panel group . The outcome of rotation could not be flat plane rotation. In the image , the rotation have to be like this , so the components can be placed fit onto the subdividing faces.
                Ah,I just found the example of rotation in this link. I think it works :    [http://sketchucation.com/forums/viewtopic.php?f=15&t=41419](http://sketchucation.com/forums/viewtopic.php?f=15&t=41419)
                Thanks once again for good advice.
                Rotate panels parallel to the floor
                  renderiza
                  Hi, this might be the way to get them all flat...
                     @sel.clear
                     @sel.add cw1sample
                     faces = @sel.grep(Sketchup;;Face)
                         PI = Math.acos(-1)
                         @rot = Math;;acos(face.normal.z)*(180/PI)
                     tr1 = Geom;;Transformation.rotation(ORIGIN, X_AXIS, -@rot.degrees)
                     tr2 = Geom;;Transformation.new([0, -300, 0])
                     instance = instance.transform!(tr2)
                     @sel.clear
                     @sel.add cw2sample
                         PI = Math.acos(-1)
                     tr2 = Geom;;Transformation.new([200, -300, 0])
                     @sel.clear
                     @sel.add cw3sample
                         PI = Math.acos(-1)
                     tr2 = Geom;;Transformation.new([400, -300, 0])
                     @sel.clear
                     @sel.add cw4sample
                         PI = Math.acos(-1)
                     tr2 = Geom;;Transformation.new([600, -300, 0])
                     @sel.clear
                     @sel.add cw5sample
                         PI = Math.acos(-1)
                     tr2 = Geom;;Transformation.new([800, -300, 0])
                  Hope this is what you were looking for...cheers!
                  • pingpinkP Offline
                    pingpink
                    Thank you very very much Renderiza !
                    After running a code , there's an error about the constant's name of " PI "
                    PI = Math.acos(-1)
                    So , I changed it to be
                    pi = Math.acos(-1)
                    And it works perfectly to copy out the different panel types !
                    I'm wondering again , in case of " RE-TAG NO." of face to change a new name and
                    a new colour. I defined the variables to relate with the function of copyout_rotate2.rb
                    @cw6 = []
                    @cw7 = []
                    @cw8 = []
                    @cw9 = []
                    @cw10 = []
                    But there's a SyntaxError in this part of condition between 'and'...
                    Not sure if there's a limitation of values. My intention is to do a copy flat panel at the end result after finished tagging panels , but in some cases of same area panel would have different patterns or materials , so they should have different names , and colours to replace the correct panel components.
                    				and face.area.to_i != @cw6area
                    				and face.area.to_i != @cw7area
                    				and face.area.to_i != @cw8area
                    				and face.area.to_i != @cw9area
                    				and face.area.to_i != @cw10area
                                @cw1 << face
                    The RE-TAG IDEA
                    Example of re-tag and copy out a panel on a model base
                    This is a re-tag option
                    Copy out the different coloured faces
                    • TIGT Online
                      But then again...
                      Math::PI
                      gives you PI without the convolution,
                      as does
                      180.degrees
                      I don't understand the unneeded complexity...
                      • tt_suT Offline
                        tt_su
                        Pi is part of the Math module: Math::PI
                        Also, beware that there is an important difference between and and && as well as or and ||. https://www.tinfoilsecurity.com/blog/ruby-demystified-and-vs
                        • pingpinkP Offline
                          pingpink
                          Thanks TIG , tt_su
                           pi = Math::PI is Math.acos(-1) ?
                           It has a same result after testing a code.
                           I read in the link , thinking that it should be put in a pair at the same line.
                           There's no errors.It works!
                          			  face.area.to_i != @cw4area and face.area.to_i != @cw5area and
                          			  face.area.to_i != @cw6area and face.area.to_i != @cw7area and
                          			  face.area.to_i != @cw8area and face.area.to_i != @cw9area and
                                      @cw1 << face
                            BUT , it my RE_TagNo.rb seems doesnt't link with the copyout_rotate2_and.rb to bring out the re-tag face panel.
                          ###### ADDING
                          	faces = sel.grep(Sketchup;;Face)
                          	@cw6 = []
                          	@cw7 = []
                          	@cw8 = []
                          	@cw9 = []
                          	@cw10 = []
                          		if @cw6.first == nil
                                      @cw6area = face.area.to_i
                          		elsif @cw7.first == nil
                                      @cw7area = face.area.to_i
                          		elsif @cw8.first == nil
                                      @cw8area = face.area.to_i
                          		elsif @cw9.first == nil
                                      @cw9area = face.area.to_i
                          		else @cw10.first == nil
                                      @cw10area = face.area.to_i
                          if input[1] == "Orange"
                                 #attribute_name = input[0].name
                                 #face.area.to_i == @cw6area
                                 faces.each do |e|
                          	   e.material = [255,165,0]#Orange
                          RE_TagNo.rb
                          • pingpinkP Offline
                            pingpink
                            Thank you very much,Renderiza !
                                 I've tested the codes , it works very good.I can see the different panel types by coloured faces. I noticed the same face area of the sloped faces and the upright faces , they have different colours.I don't know why it happens for this time , I will look later.
