    Face-tag number
    12 Posts 4 Posters 1.2k Views 4 Watching
    • renderizaR
      renderiza
      @pingpink said:
      I noticed the same face area of the sloped faces and the upright faces , they have different colours.I don't know why it happens for this time , I will look later.
      Not sure myself why that is happening but will look into it.
      @pingpink said:
      I just tried to map components on coloured faces , but I have to select faces and a panel component together to place and copy on the faces.
      Not sure that I have to do the attribute's name on coloured faces to have the same names as component's names for component mapping.
      To avoid having to select coponents and faces manually maybe try adding the code below to the one on top. Note that you have to name the component definition name manually.
      components = ents.grep(Sketchup;;ComponentInstance)
      ## cw1 ##
      components.each do |component|
      	if component.definition.name == "cw1"
      		@sel.add component
      @sel.add @cw1
      ## Put code that place component copy to face here ##
      @sel.clear #Clears selection to select cw2
      ## cw2 ##
      	if component.definition.name == "cw2"
      		@sel.add component
      @sel.add @cw2
      @sel.clear
      ## cw3 ##
      	if component.definition.name == "cw3"
      		@sel.add component
      @sel.add @cw3
      @sel.clear
      ## cw4 ##
      	if component.definition.name == "cw4"
      		@sel.add component
      @sel.add @cw4
      @sel.clear
      ## cw5 ##
      	if component.definition.name == "cw5"
      		@sel.add component
      @sel.add @cw5
      Hope this helps and your plugin look very good from the video I saw...very impressive! πŸ‘
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • pingpinkP
        pingpink
        Thank you kindly for your recommendation , it's my task to do facade modeling. I'm revising codes in each module now to make it better.
        I'm curious that Is there a way to do a code for copying different coloured panels and lay down on a base in the program ? For example , in a picture there are 2 different panels and I want to copy out. So, it can reduce a time of copying faces to draw patterns and convert to components, and then do mapping prototype panels back onto faces.
        Copy different panels to make a component later.
        • renderizaR
          renderiza
          Hi, here is one example on how to do what you mentioned. Add the following code bellow the one on top...
          @model = Sketchup.active_model
          @sel = @model.selection
          @ents = @model.active_entities
          if @cw1.first != nil
          	@sel.clear
          	cw1sample = @cw1.first
          	@sel.add cw1sample
          	cw1group = @ents.add_group(@sel)
          	tr1 = Geom;;Transformation.new([0, -300, 0])
          	instance = @ents.add_instance(cw1group.definition, tr1)
          	instance.transform!(tr1)
          if @cw2.first != nil
          	@sel.clear
          	cw2sample = @cw2.first
          	@sel.add cw2sample
          	cw2group = @ents.add_group(@sel)
          	tr1 = Geom;;Transformation.new([200, -300, 0])
          	instance = @ents.add_instance(cw2group.definition, tr1)
          if @cw3.first != nil
          	@sel.clear
          	cw3sample = @cw3.first
          	@sel.add cw3sample
          	cw3group = @ents.add_group(@sel)
          	tr1 = Geom;;Transformation.new([400, -300, 0])
          	instance = @ents.add_instance(cw3group.definition, tr1)
          if @cw4.first != nil
          	@sel.clear
          	cw4sample = @cw4.first
          	@sel.add cw4sample
          	cw4group = @ents.add_group(@sel)
          	tr1 = Geom;;Transformation.new([600, -300, 0])
          	instance = @ents.add_instance(cw4group.definition, tr1)
          if @cw5.first != nil
          	@sel.clear
          	cw5sample = @cw5.first
          	@sel.add cw5sample
          	cw5group = @ents.add_group(@sel)
          	tr1 = Geom;;Transformation.new([800, -300, 0])
          	instance = @ents.add_instance(cw5group.definition, tr1)
          I had to make face that you want to copy & move a group so at the end they are still groups. Not sure if you want to explode them back to lose face but I am sure there is a way to do that. Anyways hope this help...cheers!
          • pingpinkP
            pingpink
            Thank you so much ! , The code is amazing to copy tag faces. The group result suits with my code to convert groups to components and create the center axis on the panel plane , but my code can do mapping components on faces only the component which is parallel to the floor, not vertical exactly copy from the model. So , I tried to rotate panels by this code :
               #tr1 = Geom;;Transformation.new([0, -300, 0])
               pt = [300,0,0]
               v = Geom;;Vector3d.new(1,0,0) # The axis position to rotate opanel
               tr1 = Geom;;Transformation.rotation(pt,v,-45.degrees)
            The code cannot be used properly if there is a slope panel group . The outcome of rotation could not be flat plane rotation. In the image , the rotation have to be like this , so the components can be placed fit onto the subdividing faces.
            Ah,I just found the example of rotation in this link. I think it works :    [http://sketchucation.com/forums/viewtopic.php?f=15&t=41419](http://sketchucation.com/forums/viewtopic.php?f=15&t=41419)
            Thanks once again for good advice.
            Rotate panels parallel to the floor
            • renderizaR
              renderiza
              Hi, this might be the way to get them all flat...
                 @sel.clear
                 @sel.add cw1sample
                 faces = @sel.grep(Sketchup;;Face)
                 faces.each do |face|
                     PI = Math.acos(-1)
                     @rot = Math;;acos(face.normal.z)*(180/PI)
                 tr1 = Geom;;Transformation.rotation(ORIGIN, X_AXIS, -@rot.degrees)
                 tr2 = Geom;;Transformation.new([0, -300, 0])
                 instance = instance.transform!(tr2)
                 @sel.clear
                 @sel.add cw2sample
                     PI = Math.acos(-1)
                 tr2 = Geom;;Transformation.new([200, -300, 0])
                 @sel.clear
                 @sel.add cw3sample
                     PI = Math.acos(-1)
                 tr2 = Geom;;Transformation.new([400, -300, 0])
                 @sel.clear
                 @sel.add cw4sample
                     PI = Math.acos(-1)
                 tr2 = Geom;;Transformation.new([600, -300, 0])
                 @sel.clear
                 @sel.add cw5sample
                     PI = Math.acos(-1)
                 tr2 = Geom;;Transformation.new([800, -300, 0])
              Hope this is what you were looking for...cheers!
              • pingpinkP
                pingpink
                Thank you very very much Renderiza !
                After running a code , there's an error about the constant's name of " PI "
                PI = Math.acos(-1)
                So , I changed it to be
                pi = Math.acos(-1)
                And it works perfectly to copy out the different panel types !
                I'm wondering again , in case of " RE-TAG NO." of face to change a new name and
                a new colour. I defined the variables to relate with the function of copyout_rotate2.rb
                @cw6 = []
                @cw7 = []
                @cw8 = []
                @cw9 = []
                @cw10 = []
                But there's a SyntaxError in this part of condition between 'and'...
                Not sure if there's a limitation of values. My intention is to do a copy flat panel at the end result after finished tagging panels , but in some cases of same area panel would have different patterns or materials , so they should have different names , and colours to replace the correct panel components.
                if @cw1.first == nil
                              if face.area.to_i != @cw2area
                				and face.area.to_i != @cw3area
                				and face.area.to_i != @cw4area
                				and face.area.to_i != @cw5area
                				and face.area.to_i != @cw6area
                				and face.area.to_i != @cw7area
                				and face.area.to_i != @cw8area
                				and face.area.to_i != @cw9area
                				and face.area.to_i != @cw10area
                            @cw1 << face
                            @cw1area = face.area.to_i
                The RE-TAG IDEA
                Example of re-tag and copy out a panel on a model base
                This is a re-tag option
                Copy out the different coloured faces
                  But then again...
                  Math::PI
                  gives you PI without the convolution,
                  as does
                  180.degrees
                  I don't understand the unneeded complexity...
                  • tt_suT
                    tt_su
                    Pi is part of the Math module: Math::PI
                    Also, beware that there is an important difference between and and && as well as or and ||. https://www.tinfoilsecurity.com/blog/ruby-demystified-and-vs
                    • pingpinkP
                      pingpink
                      Thanks TIG , tt_su
                       pi = Math::PI is Math.acos(-1) ?
                       It has a same result after testing a code.
                       I read in the link , thinking that it should be put in a pair at the same line.
                       There's no errors.It works!
                                    if face.area.to_i != @cw2area and face.area.to_i != @cw3area and
                      			  face.area.to_i != @cw4area and face.area.to_i != @cw5area and
                      			  face.area.to_i != @cw6area and face.area.to_i != @cw7area and
                      			  face.area.to_i != @cw8area and face.area.to_i != @cw9area and
                                  @cw1 << face
                        BUT , it my RE_TagNo.rb seems doesnt't link with the copyout_rotate2_and.rb to bring out the re-tag face panel.
                      ###### ADDING
                      	faces = sel.grep(Sketchup;;Face)
                      	@cw6 = []
                      	@cw7 = []
                      	@cw8 = []
                      	@cw9 = []
                      	@cw10 = []
                      		if @cw6.first == nil
                                  @cw6area = face.area.to_i
                      		elsif @cw7.first == nil
                                  @cw7area = face.area.to_i
                      		elsif @cw8.first == nil
                                  @cw8area = face.area.to_i
                      		elsif @cw9.first == nil
                                  @cw9area = face.area.to_i
                      		else @cw10.first == nil
                                  @cw10area = face.area.to_i
                      if input[1] == "Orange"
                             #attribute_name = input[0].name
                             #face.area.to_i == @cw6area
                             faces.each do |e|
                      	   e.material = [255,165,0]#Orange
                      RE_TagNo.rb
                      • pingpinkP
                        pingpink
                        Thank you very much,Renderiza !
                             I've tested the codes , it works very good.I can see the different panel types by coloured faces. I noticed the same face area of the sloped faces and the upright faces , they have different colours.I don't know why it happens for this time , I will look later.
