    Vray 1.49 for Sketchup 2013
    extensions
    13 Posts 9 Posters 25.8k Views 9 Watching
    • G Offline
      Gunzii
      Hi there, Dont know if this was asked already.. but will Vray 1.049 ever work on latest Sketchup 2013? Just want to make sure. Thanks
        1.49.01 has been working in SketchUp 2013 just as it did in SketchUp 8 and previous versions. When you install, make sure to specify the path to your SketchUp 2013 installation.
          SauronBlue
          I've been trying to install cray 1.4901 for sketchup over and over with no luck. I've tried academic licences, demos, cracked dl files, nothing seems to make a change to my sketchup 2013. There are no exe's to start vray, no plugins or toolbars. I've spent the past 13 hrs getting more and more frustrated. What the heck is going on? Why is nothing working for me? I'm on win7, and everything else works fine, but I wanted to compare vray to shaderlight while I still have trial time with both to test them out. I'm new to all this, have no idea what render programs are good at what, and there are way too many choices, but I'm realizing that the vast majority of textures n stuff are for vray, so I really wanna try it out. Please help b4 I pull out all my hair!
            For which you have been banned.
            • FrederikF Offline
              Frederik
              Great move, Gai... πŸ‘
              I really like that SCF are banning such users...
              Piracy should never be accepted or tolerated...!
              Cheers
              Kim Frederik
                SauronBlue
                excellent. thanks a lot. I'm having trouble using the file downloaded from the maker of the software, I've got their permission to try it. I look all over the web for help, can find none, so I try every file I can to see if maybe what I have is corrupted, since no one else in the world seems to have an issue. Still no luck. I find a site with a similar issue, and reach out for help, but you ban me? Thanks a lot, you guys rock! Let's give each other hi-fives about rashing on the newcomer, Yeah!! Way to go, man!!
                I broke a rule I didn't know you had, before I even knew you existed, and you're proud of being jerks to me? Seems like "help" I can do without
                  When registering, you agreed our terms of use, namely the point about copyright: http://sketchucation.com/tos#copyright-policy
                  • dkendigD Offline
                    dkendig
                    😞 for reference, for anyone that comes across this post from a frustrated user, we do have support options available. I understand the frustrations of technical difficulties, and that's why we offer support for our products: http://www.chaosgroup.com/en/2/support.html
                    Devin Kendig
                    Developer
                      arquitectura321
                      Hi;
                      I have the vray 1.49 for Sketchup 7 PRO and I just bought the Sketchup 13 version but my vray it doesn't appear on the plugins on my Sketchuip 13 but it does appear when I open the Sketchup 7 y previously bought. How can I pass my vray to the Sketchup 13 folder?
                      Thanks!!
                      NOTE: The vray version i bought is the EDUCATIONAL VERSION and the sketch up version I bought is the SKETCHUP 13 PRO.
                      • andybotA Offline
                        andybot
                        It's better to make a new post in the vray sub-section of this forum instead of responding to this one. That said, the solution should be to completely uninstall vray from your machine. Restart. Then install vray again, but point to the SU2013 program folder for where you want the plugin installed. You can't just move vray plugin files, as there are other files vray uses that are elsewhere on your computer.
                          arquitectura321
                          Thank you! I'm going to do as you said. I can share the result in a new post
                          Thanks!
                          • dkendigD Offline
                            dkendig
                            you just have to run the installer again, and choose the SketchUp 2013 installation folder, rather than 7 or 8
                            Devin Kendig
                            Developer
                              shotay
                              Help!what vray version is the best for sketchup 2013?thnk u
