    Rendering Problem with shadow setting in Vray
    renderpluginsextensions
    3 Posts 2 Posters 580 Views 2 Watching
    • rishikeshavateR
      rishikeshavate
      hi friends,
      I rendered a model with default shadow setting. It looks good.
      But when i change shadow setting to +5.30 UTC it look yellowish.
      I attached both images.
      Why this is happening? I tried changing date and time also. but output is not like the first one.
      How i overcome this?
      regards,
      Default shadow setting. (UTC -7.00)
      Changed shadow setting (UTC +5.30)
      • chonC
        chon
        Maybe your project is located near Tchernobyl ? πŸ˜„ πŸ˜„
        Well, i've never seen that... πŸ€“
        Just a thing : Before playing with time zone in the shadows options, be sure that your project is well geo-located. For exemple, your project is located in London and you set your time zone on +12.00 UTC, if you render your scene at 12.00 (midday), the result will be 12.00 + 12.00 = 24.00 (midnight)... πŸ˜‰
        SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win11-64Bits
        • rishikeshavateR
          rishikeshavate
          Thanx Chon for ur reply.
          i will check for the geo-location.
          And by the way my project is located in India. πŸ˜„ πŸ˜„
