    Landform texturing issue
    4 Posts 3 Posters 270 Views 3 Watching
      danosborne
      I've created a reasonably large and detailed landform model from a set of 3D contours which I would like to texture with an aerial image.
      However, when I apply the aerial using the projected texture method, only a small fraction of the landform faces actually become textured, see image below.
      Does anyone know what would cause this issue and how I could be solved?
      Cheers,
      Dan.
      http://i.imgur.com/sKJ28co.jpg
      • panixiaP Offline
        panixia
        use this: http://sketchucation.com/forums/viewtopic.php?t=44552
        • mitcorbM Offline
          mitcorb
          I have a question. Something came to mind while looking at the image. Would this mottled effect have anything to do with duplicate faces or reversed faces? Probably not, just asking.
            danosborne
            I managed to find my issue.
            When creating a surface from contours, I did not realise the resulting entity is a group. So I was actually applying the texture to the group, rather than the actual surface. When I went into the group and directly applied to the surface, it worked properly.
