    Ability to enter a value for FOV or the eye height in 2013?
    4 Posts 3 Posters 729 Views 3 Watching
      make
      Does anybody know what happened to the ability to key in the desired value for the FOV or the eye height.
      I now get the shift part for the FOV, but what about the eye height?
      Is there a means to enter values anymore????? It was quick and efficient.
        It works for me as it has in previous versions. What tool(s) are you selecting before entering the values?
        Are you use selecting Look Around tool to set Eye Height?
          make
          The FOV issue is one that TRimble acknowledged. It doesn't work like before:
          This is a known issue that we're investigating. If you press "Tab" or click in the measurements box to adjust the value you can see this error. To work around the problem, click once to start using your SketchUp tool, move your mouse a bit, then start typing right away without clicking or tabbing into the Measurements box. You can then specify your exact value, then press return.
          • cheddaC Offline
            chedda
            Thanks make that fixed it for me regarding dof circle & arc sides etc. I really thought i was going mad or that sketchup now was different. I was even hunting for a guilty plugin. Let's hope an update patch will soon fix this.
            Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
