    [solved] SU2013 M1 (Make) Performance
    10 Posts 3 Posters 815 Views 3 Watching
    • A
      Anton_S
      Accidentally came across SU2013 M1 (Make) performance thing, and the solution. Even though fix is easy, but still SU team must fix it!
      • thomthomT
        Hmm... But since you don't changed a setting I wouldn't think that toggle in the preferences did anything other than changing the selection of that listbox back and forth...
        • thomthomT
          I tried using the Test.time_display method, first three runs straight after starting SU, then doing that selection box toggle which you did, then three new runs. They Where all consistent at ~31.3 - ~31.2s.
          If you did your test five times in a row, without going into the Preferences, what are the times then?
          test_time_display.skp
          • A
            Anton_S
            Yes, toggling didn't do anything, I just wanted it to update OpenGL settings. Maybe clicking the ok button would do it.
            You have Make or Pro? I came across this on Make.
            • A
              Anton_S
              I tried your model, and Test.time_display:
              Prior to updating OpenGL settings:
              28.1
              27.7
              27.6
              25.7
              24.4
              • It's strange that the more times I do it, the slower it gets, even after I clear console.
              After:
              30.9
              31.7
              31.1
              30.9
              31.3
              • thomthomT
                Pro. But Make and Pro should be the same.
                Maybe it's a graphic card/drive thing?
                • A
                  Anton_S
                  Hmm, I'm not sure about that. See this topic: Game running half the speed in SU 2013 vs SU 8
                  We must get more users to test this out on make and post their results. Then we can decide if it's a graphics card thing or not. Using your model, and Test.time_display is the easiest way to do so.
                  Everyone please test this out!
                  • J
                    JuanV.Soler
                    @anton_s said:
                    Hi I think this request would be better placed in the proper SketchUp Discussions for people to get acknowledged
                    salud ¡
                    • A
                      Anton_S
                      I don't quite know what I did, but now everything works well! Though, I remember going to nvidia control panel, and clicking the restore button; after it, I didn't check anything, but now it works. So, if anyone meets that problem, just go to your graphics control panel and 'restore defaults'
                      Thank you ThomThom for leading to solution 😉
                      • thomthomT
                        Good to hear it's working! 😄
