    Layout Scrapbook
    layout
    3 Posts 3 Posters 1.8k Views 3 Watching
      comfortarchitecture
      I've created a lot of good architectural symbols in Layout files and would like to copy them to a Scrapbook. But when I copy a symbol and try to paste it into the Scrapbook, nothing happens.
        A Scrapbook is really a .layout file containing reusable parts.
        You can do a Save_as Scrapbook in LO file menu...
        You can also store files in a Scrapbook by dragging and dropping the files onto the Scrapbook pane...
        You should get one entry per page. You can edit these scrapbook files from within Layout...
          sonder
          Simply place the symbols on a page, and go to file/save as scrapbook.
          If you want to place them in an existing scrapbook, choose the scrapbook, hit edit. This will open it as a standard layout file. Then paste, save and close and you are good to go.
