    Wide angle Views
    renderpluginsextensions
    3 Posts 2 Posters 646 Views 2 Watching
    • N
      n3v
      Hi All
      I am giving the new Vray 1.6.23 and sketchup Make ago. This is probably quite a simple question but I would like to do a very wide angled view or at least one that to the same ratios of say an a3 piece of paper. My screen is unfortunately very square and it seems the vray view is linked to it. I tried making the view wider using the viewport overide dimensions but it just cut the top and bottom off the screen to make it wider.
      Any ideas
      Thanks in advance
      • V
        valerostudio
        ThomThom's Vray Tools will allow you to adjust the viewing ratio.
        http://sketchucation.com/forums/viewtopic.php?p=119728#p119728
        • N
          n3v
          hi, sorry the non reply was on a deadline, in the end I used a different monitor that had the correct ratio i wanted, not the correct answer but it worked
