    2D CAD export problem SKP Pro 8
    3 Posts 2 Posters 426 Views 2 Watching
    • A
      arcsurvey
      For some reason my CAD export has stopped working properly from SKP to CAD.
      It has always worked in the past including earlier today, but for some reason now when I export to CAD all I get is one or two lines n the CAD file or nothing at all.
      I am using AutoCAD LT 2014 and SKP Pro 8. As I say it has worked up until today with this model and all of a sudden has stopped working. I have shut down and restarted to see if that helped. I have looked in the options box and tried different settings but no success.
      Any ideas?
      Regards,
      Richard.
      • K
        kaas
        no idea whats wrong but if you´re in a hurry you could try sending the file to layout and export from there to dwg?
        • A
          arcsurvey
          Thanks Kaas. I have worked it out. I have a skydome in the model and although it does not interrupt the view in sketchup it hides it when exporting. Switched it off and all is well.
          Simple, but took me a few hours to work it out.... First time I have used a skydome in a long while.
