    Slow Sketchup
    6 Posts 5 Posters 455 Views 5 Watching
    • KathrynGK
      KathrynG
      Having looked at a plethora of SU tutorials and read as much as I can get my hands on, I do know that having too many faces is not beneficial to fast modeling. However, I do need some advice please. I am about to start a rather large (I am guessing it would be considered large?) model of a wedding reception room. The room is 156'x90' and I am working in wire frame which I hoped would speed things up a bit.
      So far I have attempted to place one table with 12 chiavari chairs from the 3D warehouse, and the time that SU took to place the table and then for me to move it, with 30 tables and then all the other additions of the bars and dance floor, stage, decor etc., the couple will be celebrating their first anniversary before I can even get the model completed! I have downloaded polyreduce, and which I am going to try on the table component as soon as posting this, but I was hoping that some kind soul out there could give me some advice on what I can and should do to speed up this process, because I will never be able to do the model at this rate.
      Thank you
      "With SketchUp - Rome could have been built in a day!"
      • V
        valerostudio
        3D Warehouse models are not great. Most of hi poly, use awful textures and are not good models to work with. Get an account at Form Fonts and you will thank me. It will pay for itself in one job.
        • M
          mwm5053
          this will do the trick http://sketchucation.com/forums/viewtopic.php?p=180536#p180536
          2011 iMac
          SU 2015 Pro, 2017 Make
          V2 Twilight
          macOS Sierra 10.12.5
          • R
            rv1974
            close entity info
            • M
              mwm5053
              and outliner
              2011 iMac
              V2 Twilight
              • renderizaR
                renderiza
                Gosu by Renderiza : http://sketchucation.com/forums/viewtopic.php?f=323&t=51919
                This plugin includes some features for replacing complex components with simple ones temporarily.
                • Set:: Proxy(Box)
                • Set:: Proxy(cline)
                Cleanup by thomthom : http://sketchucation.com/forums/viewtopic.php?t=22920
                Optimize your SketchUp model by getting rid of unnecessary elements.
                Another Sketchup Plus by dukejazz : http://sketchucation.com/forums/viewtopic.php?t=42951
                This might help you send only the component that you are working at the moment to another SketchUp and when you finish place it back where it was.
                Hope this helps,
                Renderiza
                [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
