    Fusioning components
    9 Posts 2 Posters 806 Views 2 Watching
    • E
      erzane
      I would like to make the next one :
      I have a big component with some others smaller components inside
      and I would like to fusion all small components inside for making one and final component
      I cannot break it and remake a new component because it's to gib and my pc cannot afford to break it, no more memory etc...
      the other issue us that, if I break it the basis component will stay in my component files and I cannot erase them (the ''erase'' tip is simply enabled.. strange)
      thanks
        If I understand you correctly, you have a large, nested component containing a number of components and you want to have only the large component. This is simple to do. Open the nested component for editing, select all of the internal components, choose Explode from the Context or Edit menu. When they are all exploded, close the large component. After you have done that you should be able to Purge Unused components unless those same components are used somewhere else in the model. If you are worried that your computer won't handle exploding all the components at once, select and explode only a few of them at a time.
        • E
          erzane
          I cannot doing this because it tell me ''not enough memory''
            Can you explode them one at a time?
            How big is your SketchUp file?
            Try this. Save your SketchUp file. Select and delete everything outside this big component. Purge unused components and save the file using File>Save as... Give it a different name so you don't replace the original. Then try exploding the components inside your big component, purge as above and save again.
            Go back to the original SketchUp model and delete the big component with its contents. Purge unused. Then you should be able to copy the big component from the second SKP and use Edit>Paste in Place to paste it into the original file.
            • E
              erzane
              150 mo
              I tryed all that but I didn't succeed to do it
              my pc do 5min for start sketchup, I think it is something wrong with my work, something to heavy inside
              can I try to send you the file ?
                If your file is 150 Mb I can see why you have so much problem with it.
                Is it possible to purge anything that is unused? go to Window>Model Info>Statistics and click on the Purge Unused button. Does that reduce the file size?
                Were you unable to use Save as... to save a copy of the file? Did you try deleting everything but the big component you are working on?
                • E
                  erzane
                  I am saving as all component in a new file now
                  and try to purge them sololy for see what is done
                  perhaps my buildings are to big
                  but when I did the purge in my actual 150mo file, it took me some parts of some components
                  so, purging is not a good idea in this case
                    There is something wrong with your file if purging unused removes components that are in the model space.
                    • E
                      erzane
                      now it works
                      thanks for your help
