How to delete My Layout Templates
Is there a way to delete a template from inside layout. I have made some template in My Template folder, however after modifying, I have added a space or removed a space from the template's name and so end up with two copies of basically the same template.
I haven't found a way to delete a template that I wish not to have.
Thanks in advance
Ken
You can't 'manage' your 'custom' Templates inside Layout.
Your 'custom' Layout-Templates [i.e. those listed under 'My Templates'] are in a 'user' folder.
For v2013:
C:\Users\UserName\AppData\Roaming\SketchUp\SketchUp 2013\LayOut\Templatesor for v8:
C:\Users\UserName\AppData\Roaming\Google\Google SketchUp 8\LayOut\TemplatesYou might have to switch 'view hidden' folders ON to see the folder...
Thanks TIG
Yep, that's where I found the templates. Just thought I missed something.
Ken
Register LoginAdvertisement
