    How can anyone possibly use layout
    layout
    79 Posts 15 Posters 12.8k Views 15 Watching
    • F Offline
      frv
      Since the new version 2013 I thought I give Layout a new try. Who knows. Years ago I did and it was useless. Maybe now things have changed.
      I am very experienced with Sketchup, since the beginning and also a Vectorworks user. I use Vectorworks for all things 2D.
      I had a small model of a house, nothing too complicated. Inserted it in Layout 2013 and there it was. Looked all right. Then I thought I set the view on vectors and a pizza started rolling till forever and I had to force quit Layout.
      I thought I will not do that again, inserted the same model in a new file and tried two views showing front and left side of the house. The slightest thing I wanted to do caused Layout to stall forever and so I thought its still useless.
      Am I wrong or is someone developing Layout using two simple volumes with six sides and thinks all is going well for now. If there is anyone who can do something productive with Layout and with some serious geometry in their model help me out. Maybe I am completely missing the point or having set all sorts of parameters all wrong.
      The settings at default with a small model crashes the app to a standstill almost immediatly (28 Mb geometry, mostly due to textures)
      Francois
        timzy
        I've been using layout since it came out, well since they added the dimension tool - layout 2 I believe. It is useable but it is pretty quirky although I haven't switched to 2013 yet. The vector rendering can take a long time (5-10 minutes) if there is a lot of geometry - I only use it for hidden line ortho views after they are set to a scale and I always immediately explode them which breaks the link but leaves you with editable vector shapes. In fact it's the only way to import vector data into layout.
        I don't have any real sure fire advice. Keep the edit quality to medium most of the time. Pizza? - Mac thing yes? I'm on windows so maybe it works better. I don't use any proper drafting programs so for me it is the fastest way to present my models. I suspect that if you are used to a responsive. I do have a bunch of do's and don'ts that I've learned to keep things going for me but it doesn't seem like you will be able to even use layout at all.
        One thing you might try is to use it without importing a model - just to test if it works on your system at all. Bring in some images, make a few pages, add text and dimensions etc. I have found that you can copy geometry form sketchup and paste it into layout - and it seems to be more responsive than linking to a model - might be worth a shot.
        Good luck (I was getting ready to buy 2013 but I think I'm going to wait a week or two and see how people are making out with it).
        • KrisidiousK Offline
          Krisidious
          What's your system... I don't experience these issues. And any hanging I had in V8 has since been addressed, such as vector rendering.
          By: Kristoff Rand
          • F Offline
            frv
            I am on a Macpro, 8 core 3Gh.
            I think for my use Layout is completely useless. I will give it another try with a model as simple as possible. But I don't think Layout is anywere near a productive solution. This was nr. 1 reason nobody uses Layout and I am afraid that will stay that way for a long time.
            I know there are a few that go through the hassle to figure out how to minimize models and workflows to get something out Layout. But once you get your work done in Vectorworks or the likes you quickly forget the frustrations in layout. The idea behind Layout is great though. Wish it provided a true CAD experience.
            Francois
              I use LayOut all the time and I find it works just fine. I don't have any problems with rendering times now with LO2013. Even on large, complex models, rendering goes very quickly. The other day I had to make changes to a model and update two sets of construction documents. the change in sketchUp took me about 10 minutes and between the two documents I probably spent a total of five minutes updating them. Most of that time was spent opening the files and redoing some text and dimensions. Very minor time investment for the results and I delivered the revised PDF files to the client in less than 30 minutes.
              • F Offline
                frv
                ok, thats hopefull. Considering your reply I have to dig into Layout a little further.
                But to follow advise from someone who dreams about inspecting mirrors...
                Anyone else who thinks Layout just works fine ?
                Francois
                  Francois, I will tell you that if you aren't establishing the views you want as scenes in SketchUp, you're probably wasting your time with LayOut. There is a proper work flow for this stuff. Follow it and it should work just fine. If you aren't doing that, it isn't fair to denigrate the software.
                  • F Offline
                    frv
                    ok, got that. I will try some more.
                    But its rather clear very few use Layout and that is strange considering the amount of architect-users.
                    I think many have the same experience I have. But still, you are right. If there is a workflow that makes up for it I will try to find it. I can clearly see advantages if Layout can do even just a little of what it promises.
                    Francois
                    • O Offline
                      otb designworks
                      For what it's worth, I generated over 600 pages of blueprints, shop drawings, and general detail work in layout last year alone.
                      For me, it is indispensable, and that is with all of it's short comings.
                      As Dave said, it really is all about workflow. Fine tune that and it is only mildly frustrating. Don't have a a clean and organized workflow and it can be downright miserable.
                      Cheers, Chuck
                      OTB Designworks is on Youtube
                      • F Offline
                        frv
                        tx Chuck,
                        My problem is also that Vectorworks in 2D is as fast as you will ever need. No lagtime at all what ever you do. Drawings look amazing and you can just import any modeling geometry from Sketchup into Vectorworks. With Layout I am hoping for a more refined modeling-2D/output workflow were models update the 2D work instead of having to redo a lot in Vectorworks. A bit more of a revit experience in a positive sense 😄
                        Layout could easily be as big as Sketchup. I do understand how powerful the potential is. As said, the replies make me want to give it another try. But as said as well, anyone who has hit a brick wall with Layout I would urge to reply saving me time trying.
                        Francois
                          I don't know why you're looking for people who have hit a brick wall with LayOut. If they have it's their own fault because they haven't learned how to use it correctly. Do you want reviews on how a motorcycle drives from people who doesn't know how to drive one?
                            timzy
                            Layout simply does not have the sophisticated line drawing workflow of a nice drafting package like Vectorworks. There is a strong tradition of communicating 3D projects through 2D drawings using delicate line weights and styles. When an art director says "make that line dashed" or "make that one thicker and red" it can't just happen like in a 2D drafting set up.
                            I believe that building projects as 3D models is a much more efficient and sophisticated way to design but we still have to commit it to paper to communicate. If you have a clean, accurate 3D build then layout is definitely the fastest way to present that model. Just don't expect it to produce intricate drafting documents in a traditional sense. My advice would be to rely more on the 3D as much as possible to communicate and use layout to add the details.
                            I think a good layout document can speak more clearly to a wider group of people than a traditional drawing set. Some nice 3D views, a few choice measurements, good notes and suddenly everyone has the same picture of the project - laymen, tradespeople, committee members, administrative staff, your kids - everyone.
                            Layout could be better - a lot better - but I think the big brick wall is mainly shifting gears.
                            • pbacotP Offline
                              Actually it won't be traditional. It may be better. I myself haven't delved so deep, but Sonder, Bmike, and others have shown what is possible, and the output can be quite intricate. They had to approach it in a different way than they did their former CAD (e.g. AutoCAD) and it took time to rebuild their method. But we now have examples, books and videos mounting, to give the rest of us an idea of how to proceed. For myself, I use LO for presentation of 3d and 2d schematics, and I use it for the elevations for CD's.
                              Like you I already have my 2d CAD method which is more direct. And I will not bother to transition until there's a need or advantage. If I do need to make minor changes it IS many more steps to output in SU-LO. But I think this time lag lessens with getting your workflow to become second nature. I can relate to the processing lags for each step, especially in LO rendering, even with an 8 core Pro. I hope 2013 does indeed improve that. I know that the most recent SU-LO job I did would have been impossible before I got my (latest-highest build) MBP. So I hope the "under-the-hood" improvements show up in even more performance down the road. Just hoping.
                              But your spinning beach ball issues don't relate to my experience. If the file is reasonable in SU, it should be at least "doable" in LO.
                              • arail1A Offline
                                arail1
                                If you have the time would you consider expanding on the comments above? I stumble around in Layout, using it mainly to format 3D output without annotations. I'm sure I'm not alone in needing some insight into a more productive workflow with the program.
                                  sonder
                                  As stated above, you need to approach the use of Layout with an entirely different work flow than you would with traditional CAD programs. I only use SU and LO for all my work, and I can confirm that extremely detailed sets of drawings can be produced extremely fast. I am at my 9th set of detailed CD's in the past 12 months, to different building departments, with zero comments being issued. I attribute this to the level of detail I am able to provide. A level that is simply too cumbersome to provide in traditional CAD programs.
                                  The slowness you are seeing, given the 8 core processor, is due to either a crappy video card in that MAC or more likely, you are trying to vector render and entire SU model.
                                  You just need to take more time with it and figure out where the strengths lie.
                                  • F Offline
                                    frv
                                    I know about how to convert to 3D modeling and communicating on paper.
                                    I am not looking for all that refinement in 2D at all.
                                    Just a resonable workflow were elevations and some perspectives, maybe a "filled" crosssection with some basic dimensions tell the story of first tryouts of a design.
                                    If this means going complete slowmotion, lets say 90% waiting for redraws and the occaisional input from my side I would go mad. That is how it feels now and to many others I assure you.
                                    So we are doing something wrong. Not just a little here or there but a major step is not clear stalling even the easiests of tasks to a standstill.
                                    I will go and see what it is. But its sure not Sketchup which to me is always fast enough.
                                    Tx, really for the replies, very appreciated.
                                    Francois
                                      Francois, I don't know how many times I've written this on this forum in the last few weeks but render times with 2013 are so much shorter than in LO3 that I can render entire highly detailed models in only a few minutes. I'm not sitting waiting for the renders to complete like I was with LO3.
                                      Arail, you should look at Sonder's videos showing how he works.
                                        Krisidious
                                        Vector rendering perspective views on complex models still takes some time... but not nearly as much and should complete in a reasonable time... a few seconds? under a minute.
                                        By: Kristoff Rand
                                        • F Offline
                                          frv
                                          well.... I am not going to use Layout anyhow no matter how many times
                                          ok, sorry, I could not help that, I was just distracted by these smilies. Who ever uses these critters. But its late and so ..
                                          tx for the help so far. I am going to set my self up with something simple enough to test with.
                                          If I hear you all right it should be working and in a productive way as well.
                                          I think all has been said about my outcry here on Layout. It seems a matter some basic training. Lets see were I get with that.
                                          Francois
                                          • bmikeB Offline
                                            bmike
                                            lots already said... but detailed drawings can be quick, and beautiful (IMHO) - like Sonder's work... and others.
                                            https://lh3.googleusercontent.com/-I3bxovoorfg/UBmKMN-lGPI/AAAAAAAAUxM/30L6NpCNklc/s800/8-1-12-roundbarn-section.jpg
                                            https://lh5.googleusercontent.com/-MhQehokpMDA/UBmKIReO-MI/AAAAAAAATfY/8-s5q1NkJ7I/s800/8-1-12-roundbarn-joinery1.jpg
                                            https://lh3.googleusercontent.com/-Em91oj0INbM/Te4_a1-p-MI/AAAAAAAAQYs/hwBHxIEceec/s800/poland5-25-11-metric_Page_19.jpg
                                            https://lh5.googleusercontent.com/-rmaPto38v3M/Te4_m0LDLwI/AAAAAAAAQZc/I7TCTIRTOoM/s800/poland-6-7-11-LIFT_Page_4.jpg
                                            https://lh4.googleusercontent.com/-SO6SDLsGBKQ/ThW-GEWuT_I/AAAAAAAAQhI/TVKIwPVAb0k/s800/chester-bridge-7-7-11_Page_12.jpg
                                            https://lh3.googleusercontent.com/-R9Htw0oXWOk/T-S_p5dP4QI/AAAAAAAAUxc/j71zXKmYLR4/s800/millrd-presentation_12.jpg
                                            mike beganyi design + consulting llc
                                            • 1 / 4
