    Layers Should Lock?
    13 Posts 9 Posters 939 Views 9 Watching
    • KrisidiousK
      Krisidious
      I have a set of layers in my template... If I make the mistake of purging too early in a model's progress I lose most of those layers. I normally fix this by pasting my model back into another blank template. I have another fix I'm considering where I put a small empty group on each layer in the template.
      Shouldn't Layers Be Lockable?
      By: Kristoff Rand
      • GarethG
        Gareth
        I must admit, I have never really thought about it, but it's a YES from me
        Even though I have never had any issues before, you can bet that I will sooner or later. So it would be a handy safety net.
        • FrederikF
          Frederik
          Being able to lock a layer should be standard...
          It's possible in LO and should also be possible in SU...
          Cheers
          Kim Frederik
          • A
            ArCAD-UK
            I'm hoping this also means you can't edit entities on that layer if they are locked!
            If it's just to prevent purging the layer then I'm not bothered so much, there are bigger issues.
            • jiminy-billy-bobJ
              jiminy-billy-bob
              I'll had this to the todo list for my Layers Panel plugin.
              • Mike LuceyM
                Mike Lucey
                Having the option could only be a good thing, so YES πŸ‘
                • KrisidiousK
                  Krisidious
                  awesome.
                  By: Kristoff Rand
                  • G
                    Glenn at home
                    Been wishing for this for so long. It is nice to do so in Acad (pretty much anything that uses layers). It is such a simple thing you have to wonder why it was never implemented to start with.
                    • jiminy-billy-bobJ
                      jiminy-billy-bob
                      awesome.
                      I should say that I won't be able to work on the plugin until the end of july... Sorry for the wait !
                      • KrisidiousK
                        Krisidious
                        July is better than never...
                        By: Kristoff Rand
                        • arail1A
                          arail1
                          Somewhat of an aside to the issue of being able to lock layers (+1 for that) - in AutoCAD I use what I call a 'seed' drawing as the base for all drawings. The drawing has, in the lower left corner below 0,0, a miscellaneous assembly of lines, dimensions, texts, hatches, leaders, some basic items like hardware (I do a lot of shop drawings for fabricators), architectural symbols, section cuts, etc. The purpose of the seed drawing is to make all that material readily available to me and to prevent it from disappearing when I Purge. Keeping that rats nest of stuff means that after I Purge I haven't lost my dashed line, my center line, or any of the other items that I might not be using at that moment in the drawing but likely might later on.
                          • GaieusG
                            Kris: empty layers get purged only. Could you place a guide point (say to the origin not to clutter your model) on each layer in your template?
                            • KrisidiousK
                              Krisidious
                              That was my idea Gaieus... However when I unhide all I'll run into issues. I think I'll need to put the guide inside of a group and then hide the guide inside the group. that should leave it there. Then of course I was a little worried that i would do something to all my models I might come to regret later for unknown reasons.
                              By: Kristoff Rand
