    Trying to sort scenes by alphabetical order..Need Help!
    14 Posts 5 Posters 993 Views 5 Watching
    • renderizaR Offline
      renderiza
      So far I am trying the following but when I sort them by name they all merge together into one name and I can't then iterate using .each. How I can I solve this...thanks!
      model = Sketchup.active_model ;
      pages = model.pages ;
      data = [] ;
      org = [] ;
      pages.each do |page|
        data << page.name ;
      end ;#Pages.each
      org << data.sort do |a,b| a <=> b end ;
      num = pages.count ;
      org.each do |e|
      UI.messagebox e ;
      end ;
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • Dan RathbunD Offline
        Dan Rathbun
        org = pages.map{|pg| pg.name }.sort!
        cna replace all this:
        data = []
        org = []
          data << page.name ;
        end ;#Pages.each
        org = data.sort do |a,b| a <=> b end
        PS: why are you putting ; at the end of each line ?
        I'm not here much anymore.
          Dan Rathbun
          BTW.. the API does not expose the moving of a page to a new location.
          You have to clone the page (incl. all it's properties,) to the new location, and then delete the old page.
          When you use pages.add the API uses the current selected page as the "mold".
            renderiza
            Thanks yet again!
            I though that was good practice πŸ˜•
            Keep in mind I never took a programming class in my life so I am very thankful for people steping in and pointing something that it shouldn't be done. πŸ‘
            So no need to put ";" ?
            Yes I was thinking of doing what you just suggested.
            Again Thanks a lot!
              Dan Rathbun
              only if more than 1 statement per line (like in the console.)
              Otherwise you just make your files larger, and make the interpreter read an extra character each line.
                renderiza
                Thanks that is good to know!
                  renderiza
                  Hi, here is my progress so far...
                  pages = model.pages
                  page_num = 0
                  num = pages.count
                  amount = 0
                  times = 0
                  begin
                      pages.each { |page|
                          page.transition_time=0
                          if page.name == "#{org[amount]}"
                              pages.selected_page = model.pages[page_num]
                              break
                          page_num+=1
                      } #pages.each
                  page_num = 0
                  amount += 1 if amount < num
                  pages.add "#{org[amount-1]}"
                  end while amount < num
                  begin
                  pages.selected_page = model.pages[0]
                  Sketchup.send_action(CMD_PAGE_DELETE)
                  times += 1
                  end while times < num
                  The above code will reorganize your scenes by name. The only thing I wish it would change is if it didn't have to prompt a message before deleting unwanted scenes but other than that I am happy with results!
                  If anyone have any suggestions in making my code fancier and better written please let me know.
                  Again Thanks!
                    renderiza
                    Here is little code sniped for renaming all scenes and add number...
                    pages = model.pages
                    @page_name = "Name"
                    @page_num = 1
                        page.name = "#{@page_name}#{@page_num}"
                        @page_num = @page_num + 1
                    end ;#Pages.each
                    Cheers!
                    • Chris FullmerC Offline
                      Instead of:
                      use:
                      my_page = model.pages[0]
                      model.pages.erase( my_page )
                      That will delete the page without issuing a warning to the user.
                      All my Plugins I've written
                        #You are over complicating it somewhat.
                        #Also it's a bit clearer if you use {}, for the new 'sorted' pages:
                        ` model = Sketchup.active_model
                        pages = model.pages
                        selpage = pages.selected_page.name
                        opages = pages.map**{**[/b] |pg| pg.name }.sort
                        num = opages.length
                        opages.each**{** |page|
                        optt = pages[page].transition_time #***
                        pages[page].transition_time = 0
                        fix delay_time too***
                        opdt = pages[page].delay_time #***
                        pages[page].delay_time = 0
                        pages.selected_page = pages[page]
                        newp = pages.add(page)
                        newp.transition_time = optt
                        newp.delay_time = opdt
                        }#***Good idea to store the original page.transition_time& delay_timeetc and reapply them to the new page... #Then similarly for removing the unsorted pages use {}... num.times**{** pages.erase(model.pages[0]) }#to erase all of the original pages. #then to restore the originally selected page by name, add... pages.selected_page = pages[selpage]`
                        πŸ˜„
                          renderiza
                          Thank you both very much!
                          This was the best feedback I could hope for! 😍
                          Cheers!
                            Dan Rathbun
                            @renderiza said:
                            ... The only thing I wish it would change is if it didn't have to prompt a message before deleting unwanted scenes ...
                            replace:
                            with:
                            pages.erase *some_page_object_ref*
                            πŸ’­
                            • AdamBA Offline
                              AdamB
                              Following this thread, I wonder whether the OP would be better off just caching each Scene in a convenient format and simply filling the existing Scenes as 'buckets' - rather than creating and destroying objects all the time.
                              So simply set attributes, names, camera etc etc for each.
                              Adam
                                renderiza
                                I updated [Re]Scene to include the feature to reorganize all scenes by alphabetical order. Thanks for all the help!
                                New Web-Dialog:
                                http://s15.postimg.org/ycqlsebaj/dlg_1.jpg
                                Plugin Page: http://sketchucation.com/forums/viewtopic.php?f=323&t=52203
                                Cheers! πŸ‘
