    Trying to sort scenes by alphabetical order..Need Help!
    14 Posts 5 Posters 1.2k Views 5 Watching
    • renderizaR
      renderiza
      Thanks yet again!
      @dan rathbun said:
      PS: why are you putting ; at the end of each line ?
      I though that was good practice πŸ˜•
      Keep in mind I never took a programming class in my life so I am very thankful for people steping in and pointing something that it shouldn't be done. πŸ‘
      So no need to put ";" ?
      @dan rathbun said:
      BTW.. the API does not expose the moving of a page to a new location.
      You have to clone the page (incl. all it's properties,) to the new location, and then delete the old page.
      When you use pages.add the API uses the current selected page as the "mold".
      Yes I was thinking of doing what you just suggested.
      Again Thanks a lot!
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • Dan RathbunD
        Dan Rathbun
        only if more than 1 statement per line (like in the console.)
        Otherwise you just make your files larger, and make the interpreter read an extra character each line.
        I'm not here much anymore.
        • renderizaR
          renderiza
          Thanks that is good to know!
          • renderizaR
            renderiza
            Hi, here is my progress so far...
            model = Sketchup.active_model
            pages = model.pages
            page_num = 0
            org = pages.map{|pg| pg.name }.sort!
            num = pages.count
            amount = 0
            times = 0
            begin
                pages.each { |page|
                    page.transition_time=0
                    if page.name == "#{org[amount]}"
                        pages.selected_page = model.pages[page_num]
                        break
                    page_num+=1
                } #pages.each
            page_num = 0
            amount += 1 if amount < num
            pages.add "#{org[amount-1]}"
            end while amount < num
            begin
            pages.selected_page = model.pages[0]
            Sketchup.send_action(CMD_PAGE_DELETE)
            times += 1
            end while times < num
            The above code will reorganize your scenes by name. The only thing I wish it would change is if it didn't have to prompt a message before deleting unwanted scenes but other than that I am happy with results!
            If anyone have any suggestions in making my code fancier and better written please let me know.
            Again Thanks!
            • renderizaR
              renderiza
              Here is little code sniped for renaming all scenes and add number...
              pages = model.pages
              @page_name = "Name"
              @page_num = 1
              pages.each do |page|
                  page.name = "#{@page_name}#{@page_num}"
                  @page_num = @page_num + 1
              end ;#Pages.each
              Cheers!
              • Chris FullmerC
                Instead of:
                use:
                my_page = model.pages[0]
                model.pages.erase( my_page )
                That will delete the page without issuing a warning to the user.
                  #You are over complicating it somewhat.
                  #Also it's a bit clearer if you use {}, for the new 'sorted' pages:
                  ` model = Sketchup.active_model
                  pages = model.pages
                  selpage = pages.selected_page.name
                  opages = pages.map**{**[/b] |pg| pg.name }.sort
                  num = opages.length
                  opages.each**{** |page|
                  optt = pages[page].transition_time #***
                  pages[page].transition_time = 0
                  fix delay_time too***
                  opdt = pages[page].delay_time #***
                  pages[page].delay_time = 0
                  pages.selected_page = pages[page]
                  newp = pages.add(page)
                  newp.transition_time = optt
                  newp.delay_time = opdt
                  }#***Good idea to store the original page.transition_time& delay_timeetc and reapply them to the new page... #Then similarly for removing the unsorted pages use {}... num.times**{** pages.erase(model.pages[0]) }#to erase all of the original pages. #then to restore the originally selected page by name, add... pages.selected_page = pages[selpage]`
                  πŸ˜„
                  • renderizaR
                    renderiza
                    Thank you both very much!
                    This was the best feedback I could hope for! 😍
                    Cheers!
                    • Dan RathbunD
                      Dan Rathbun
                      @renderiza said:
                      ... The only thing I wish it would change is if it didn't have to prompt a message before deleting unwanted scenes ...
                      replace:
                      with:
                      pages.erase *some_page_object_ref*
                      πŸ’­
                      • AdamBA
                        AdamB
                        Following this thread, I wonder whether the OP would be better off just caching each Scene in a convenient format and simply filling the existing Scenes as 'buckets' - rather than creating and destroying objects all the time.
                        So simply set attributes, names, camera etc etc for each.
                        Adam
                        • renderizaR
                          renderiza
                          I updated [Re]Scene to include the feature to reorganize all scenes by alphabetical order. Thanks for all the help!
                          New Web-Dialog:
                          http://s15.postimg.org/ycqlsebaj/dlg_1.jpg
                          Plugin Page: http://sketchucation.com/forums/viewtopic.php?f=323&t=52203
                          Cheers! πŸ‘
