    [REQ] Plugin Multi-View Elevations
    50 Posts 10 Posters 5.6k Views 10 Watching
    • KrisidiousK Offline
      Krisidious
      The easiest way to explain what I want is this symbol.
      http://i44.tinypic.com/jrvcsg.png
      I would like to have a way to drop in "something" that would produce 4 scenes in a parallel view, with each of the directional views in succession, preferably named in accordance with some method.
      Perhaps a plugin can't accomplish this... perhaps it can? Any ideas?
      By: Kristoff Rand
      • renderizaR Offline
        renderiza
        Let me see if I understood right...
        You want a plugin that prepare 4 side elevation for each group or component?
        This will mean that if you have 2 components you want to apply plugin to then it will create total of 8 scenes for creating 4 elevation for each?
        The whole trick here I guess is to center camera position for each group or component before making scenes.
        Note: I think this might be possible to do indeed but I have not tested it myself. Anyways if I ever make some tests I'll let you know...cheers!
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
          Krisidious
          no, not components... views of the entire model.
          the symbol represents a drawing like this.
          http://s3images.coroflot.com/user_files/individual_files/original_382327_XwwJ9AFXJSG7vzxWVuQiO3it2.jpg
          By: Kristoff Rand
            renderiza
            Let me give it another try to see if I fully got it...
            Do you just want the plugin to create 4 scenes with each containing an elevation view like the ones you get from Camera > Standard Views > Front, Back, Left , Right ?
            Do you also want for each scene to be named in specific way?...Maybe have view-port text to be changed from default, for example Front, Back, left, Right to something else?
            Note: If this is right then it will be much easier than the last one I thought to be. Anyways sorry if I am asking too many questions. 😳 🀣
              Search for Default Scenes in the PluginStores.
                Krisidious
                yes but the front back right and left will all be inverted... instead of all four viewing inwards toward one point they would all view outwards away from the central point...
                @Rich I don't think that will do it. I have a template with all my common scenes, front, rear, left, right, roof, foundation, level I etc. etc.
                But this one you would have to edit each scene each time because these interior elevations are done for multiple rooms, which are always in different locations in the model.
                By: Kristoff Rand
                  renderiza
                  Very good plugin indeed...thanks Rich O Brien!
                    Krisidious
                    ask all the questions you want Rafael...
                    By: Kristoff Rand
                      renderiza
                      Thanks I will! Just want to understand every detail before trying to solve it.
                      Can you offer some examples that will aid me understand this concept of inverting views because I am not quite understanding it.
                      Thanks!
                        Krisidious
                        Sure... Here's a break down of how it works.
                        By: Kristoff Rand
                          renderiza
                          Very clever idea!
                          Ok I think I got it but just in case...
                          You want to place that decal that have arrows with A, B, C, D and plugin will recognize its position and place camera origin on center of that to capture elevation from there?
                          This is a Brilliant idea!
                            Krisidious
                            yes, exactly... 4 elevations or even better if I could choose how many, because this symbol is used with 1,2,3,4 or even more directions. but normally no more than 4.
                            By: Kristoff Rand
                              Krisidious
                              @renderiza said:
                              Very clever idea!
                              I can't take credit for it... some guy way back in drafting history came up with it... or maybe his wife. 🀣
                              By: Kristoff Rand
                                renderiza
                                I gotcha...going to my lab an will report to you soon! πŸ€“
                                  Krisidious
                                  wrings hands and waits with bated breath... 😎
                                  By: Kristoff Rand
                                  • BoxB Offline
                                    One thing to keep in mind while making this. If the scene order is right it should make a good basis for a standard animation.
                                    I just had fish for dinner, so mine is baited breath.
                                      Krisidious
                                      πŸ‘
                                      By: Kristoff Rand
                                        renderiza
                                        Any ideas on what will be the name of this plugin?
                                        Cheers!
                                          Krisidious
                                          The name of the symbol is an Elevation Marker. Perhaps "MarkerMaker"?
                                          By: Kristoff Rand
                                            renderiza
                                            The name is important since it will give a hint as to what the plugin do.
                                            "Marker Maker" - Is good
                                            "Elevation Maker" - Maybe good as well?
                                            Anyways no hurry for this but its nice to start exploring ideas. πŸ‘
                                            • 1 / 3
