    [REQ] Plugin Multi-View Elevations
    50 Posts 10 Posters 6.4k Views 10 Watching
      Search for Default Scenes in the PluginStores.
      • KrisidiousK Offline
        Krisidious
        yes but the front back right and left will all be inverted... instead of all four viewing inwards toward one point they would all view outwards away from the central point...
        @Rich I don't think that will do it. I have a template with all my common scenes, front, rear, left, right, roof, foundation, level I etc. etc.
        But this one you would have to edit each scene each time because these interior elevations are done for multiple rooms, which are always in different locations in the model.
        By: Kristoff Rand
        • renderizaR Offline
          renderiza
          Very good plugin indeed...thanks Rich O Brien!
          [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
            Krisidious
            ask all the questions you want Rafael...
            By: Kristoff Rand
              renderiza
              Thanks I will! Just want to understand every detail before trying to solve it.
              Can you offer some examples that will aid me understand this concept of inverting views because I am not quite understanding it.
                Krisidious
                Sure... Here's a break down of how it works.
                By: Kristoff Rand
                  renderiza
                  Very clever idea!
                  Ok I think I got it but just in case...
                  You want to place that decal that have arrows with A, B, C, D and plugin will recognize its position and place camera origin on center of that to capture elevation from there?
                  This is a Brilliant idea!
                    Krisidious
                    yes, exactly... 4 elevations or even better if I could choose how many, because this symbol is used with 1,2,3,4 or even more directions. but normally no more than 4.
                    By: Kristoff Rand
                      Krisidious
                      @renderiza said:
                      Very clever idea!
                      I can't take credit for it... some guy way back in drafting history came up with it... or maybe his wife. 🀣
                      By: Kristoff Rand
                        renderiza
                        I gotcha...going to my lab an will report to you soon! πŸ€“
                          Krisidious
                          wrings hands and waits with bated breath... 😎
                          By: Kristoff Rand
                          • BoxB Offline
                            One thing to keep in mind while making this. If the scene order is right it should make a good basis for a standard animation.
                            I just had fish for dinner, so mine is baited breath.
                              Krisidious
                              πŸ‘
                              By: Kristoff Rand
                                renderiza
                                Any ideas on what will be the name of this plugin?
                                Cheers!
                                  Krisidious
                                  The name of the symbol is an Elevation Marker. Perhaps "MarkerMaker"?
                                  By: Kristoff Rand
                                    renderiza
                                    The name is important since it will give a hint as to what the plugin do.
                                    "Marker Maker" - Is good
                                    "Elevation Maker" - Maybe good as well?
                                    Anyways no hurry for this but its nice to start exploring ideas. πŸ‘
                                      Krisidious
                                      Elevation Maker would be good if you can also make the exterior elevations... which would be an inversion of directions. The same marker is used for exterior parallel elevations.
                                      Easy Elevations?
                                      Interioriza?
                                      Elevation Tools?
                                      By: Kristoff Rand
                                      • CadFatherC Offline
                                        CadFather
                                        sectionist πŸ˜†
                                        • BoxB Offline
                                          Multi Elevation Set Point
                                            Late to the party...
                                            ElevTag - 1 direction == outside elev marker...
                                            ElevTag4 - 4 direction == room elev marker...
                                            That's what mine is called...
                                            Unpublished for personal use...
                                            • 1 / 3
