    Remove layer
    7 Posts 5 Posters 670 Views 5 Watching
    • D
      dacastror
      hi, I ask how I can remove a layer from ruby, I could not find a way to do this,
      thanks in advance
      • TIGT
        thanks in advance
        First you must iterate all entities in the model ADD within all definitions entities, and change the layer if it matches...
        e.layer=nil if e.layer.name=="layer_to_go"
        OR us another layer...
        e.layer=layers.add('new_layer')
        Now you can do
        layers.purge_unused
        and the now unused layer is deleted...
        If you have an unused layer you'd like to retain you need to make some temporary entities using it, so that layer doesn't get purged.
        • jiminy-billy-bobJ
          jiminy-billy-bob
          TIG is being modest, but he actually wrote a snippet for it : http://sketchucation.com/forums/viewtopic.php?t=20086
          But don't use it as is, you need to modify it to use the method in your own namespace.
          Here is how I did it (There may be some mistakes, I'm just starting ruby ! So check it, but it works fine for me) :
          ### LAYER DELETE METHOD ### ------------------------------------------------------
          	#Simple modification of TIG's snippet delete-layer.rb
          	#Basically, move or delete layer content, then creates an entry for every layer except one to delete, then purge layers, then delete entries
          	def self.deleteLayer(layer, delete_geometry=false)
          		model=Sketchup.active_model
          		ents=model.entities; defs=model.definitions; layers=model.layers
          		model.start_operation ("Delete layer")
          		if delete_geometry
          			allents=[]
          			ents.each{|e|allents<<e if e.valid? and e.respond_to?(;layer)and e.layer==layer}
          			defs.each{|d|d.entities.each{|e|allents<<e if e.valid? and e.respond_to?(;layer)and e.layer==layer}}
          			allents.each{|e|e.erase! if e.valid?}
          		else ### move geom to Layer0 etc
          			ents.each{|e|e.layer=nil if e.respond_to?(;layer)and e.layer==layer}
          			defs.each{|d|d.entities.each{|e|e.layer=nil if e.respond_to?(;layer)and e.layer==layer}}
          		end#if
          		group=ents.add_group();gents=group.entities ### temporarily use other layers
          		temp=gents.add_group()
          		temp.layer=nil
          		(layers.to_a-[layer]).each{|layer|tc=temp.copy;tc.layer=layer}
          		model.active_layer=nil if model.active_layer==layer ### ensure layer is not current layer
          		layers.purge_unused ### purge layer from browser
          		group.erase! ### erase! the temporary layer user, use set as was.
          		model.commit_operation
          	end#def
          Call it with something like self.deleteLayer(layers[layerName])
          • KrisidiousK
            Krisidious
            I think a more popular command would be "Remove Lawyer"...
            By: Kristoff Rand
            • TIGT
              I did write a whole raft of 'missing' layer methods...
              I just thought I'd let you learn by doing... 😉
              • renderizaR
                renderiza
                Here is another option but I don't know if its compatible with MAC OS
                Sketchup.send_action(21537) #Delete Layer
                [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                • jiminy-billy-bobJ
                  jiminy-billy-bob
                  I learn by looking at what you wrote !
