    How to retrieve array of faces that are inside a group?
    14 Posts 3 Posters 592 Views 3 Watching
    • renderizaR Offline
      renderiza
      I want to fix my Animatex plugin to animate faces with textures even within a group but I can't manage to retrieve index of faces inside groups. Here is the Animatex forum just in case... http://sketchucation.com/forums/viewtopic.php?f=323&t=52238
      Any help will be appreciated!
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        renderiza
        The only thing that comes to my mind is raytest but I hope there is an easier way. πŸ˜’
          try something like
          faces = group.entities.grep(Sketchup::Face)
            renderiza
            I can't seem to iterate though all the groups to get all faces. Only can retrive faces if I use [0] or [1] in faces = group[0].entities.grep(Sketchup::Face) for only one group.
            Is there a way to have something like group.each kinda thing?
            model = Sketchup.active_model
            ents = model.entities
            group = ents.grep(Sketchup;;Group)
            faces = group[0].entities.grep(Sketchup;;Face)
            UI.messagebox faces
            Again thanks TIG!
              <span class="syntaxdefault">model&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />ents&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br /><br />groups&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">ents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Group</span><span class="syntaxkeyword">)<br />for&nbsp;</span><span class="syntaxdefault">group&nbsp;in&nbsp;groups<br />&nbsp;&nbsp;faces&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">group</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">end</span>
              groups.each {} also works off course.
                renderiza
                Thanks you Thomthom and TIG you both have been really kind in helping me out!
                  renderiza
                  Can I include both faces inside groups and faces out of groups in the same 'face=' variable?
                  model = Sketchup.active_model ;
                  ents = model.active_entities ;
                  groups = ents.grep(Sketchup;;Group) ;
                  for group in groups
                    faces = group.entities.grep(Sketchup;;Face)
                  How can I add this to the faces value above without overwriting it?
                  faces = ents.grep(Sketchup;;Face) ;
                  Thanks!
                    for group in groups
                      faces << group.entities.grep(Sketchup;;Face)
                    faces.flatten! ### combine []'s
                    faces.compact! ### remove 'nils'
                    ### now you have an array of 'faces' in the model's active_entities AND inside all groups in the model's active_entities...
                      > for group in groups
                      > end
                      Thomthom the code above I though retrieved all faces from all groups but only does it for one. It acts like when I used [0], any ideas?
                      Note:: Posted this before seeying TIG post... 😳
                      Let me test your suggestion TIG
                      Thanks!
                      See my post just before it uses array<< NOT array= and then a flatten! & compact! πŸ˜’
                        renderiza
                        for group in groups
                        Thanks!
                          renderiza
                          Thank you so much yet again!
                            Another variation on how to get all faces from multiple groups:
                            <span class="syntaxdefault"><br />model&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />ents&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br /><br />groups&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">ents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Group</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">faces&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">groups</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">map&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">group</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">group</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)&nbsp;}.</span><span class="syntaxdefault">uniq<br /></span>
                            The .uniq part is there just in case you have two groups that are copies of each other.
                              In my version you ought to add a closing
                              faces.uniq! ### to remove 'duplicates' if the groups have multiple copies πŸ˜’
                                renderiza
                                Very grateful indeed!
