    SketchUp crashing on me with this code...why?
    8 Posts 4 Posters 597 Views 4 Watching
    • renderizaR Offline
      renderiza
      Hi, here is part of a test I am doing to see if I can get Animatex Plugin to animate multiple faces but SketchUp keep crashing on me. Any particular reason why this happening so I can fix it?...thanks!
      If you don't know what Animatex is here is a link.... http://sketchucation.com/forums/viewtopic.php?f=323&t=52238
      One quick note is the def push_frame(dialog,data) is being updated couple frames a second by the web dialog.
      			params = query_to_hash(data) ;  # parse state information
      			if @animate == true
      				model = Sketchup.active_model
      				ents = model.entities
      				faces = []
      				ents.each do |e|
      					if e.is_a? Sketchup;;Face
      							faces << e
      				faces.each do |e|
      					mat = e.material
      					pt_array = []
      					pt_array[0] = Geom;;Point3d.new(@speed_x,@speed_y,0)
      					pt_array[1] = Geom;;Point3d.new(0,0,0)
      					on_front = true
      					e.position_material mat, pt_array, on_front
      Any help will be welcome! πŸ‘
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        I don't see how I can reproduce anything from this code. Got a complete case for testing?
        Sidenote:
        You indentation appear inconsistent. I'd recommend you keep it consistent with something like 2 or 4 space indentation. Makes it easier to read and debug.
        if @animate == true this doesn't need to be so verbose, You can do just if @animate
        ents = model.entities is that really the context you want to change? Not ents = model.active_entities in case the user opens a group/component. Maybe your crash is related to modifications in the wrong context?
        faces = []
        ents.each do |e|
            faces << e
        This is be simplified, and made faster by:
        faces = ents.grep(Sketchup;;Face)
          renderiza
          There is an attachment with a more complete code but it is still a test code...for example the @speed_x is not increasing in number yet.
          test.rbz
          Note: I am using Notepad++ and for indenting space I use tab but for some reason when I copy & paste code from there to forum it looks like that.
          Again thanks thomthom!
            What are @speed_x and @speed_y - if these aren't 'numbers' it'll cause issues.
            Perhaps trap at the code's start up with something like
            @speed_x = 0 unless @speed_x @speed_y = 0 unless @speed_y
            etc...
            Also you should trap that the two points used in the positioning-points' array are != - with something like this...
            return nil if @speed_x == 0 && @speed_y==0 ### because then pts_array[0]==pts_array[1] pt_array = [Geom::Point3d.new(@speed_x ,@speed_y, 0), Geom::Point3d.new(0, 0, 0)] on_front = true
            Note that you do not need to set the positioning-points' array etc multiple times, because it is always the same - do it outside of the 'faces' loop. Unless you intend to increment @speed_x etc inside the loop, then you need to put it in the loop...
            Also, also you are re-positioning every face's material, but if a face's material is the default-material [ nil] it'll probably throw a wobbler ??
            Try something like this near the start of the 'faces' loop...
            next unless mat = e.material
            to skip over any faces that have no material...
              Yea, as TIG says, check the values of your code. Output the values and add traps to ensure you are using valid data from start to end.
              • AdamBA Offline
                AdamB
                #position_material is quite brittle and will die if you give it anything but clean parameters.
                If memory serves, it will explode with either zero-area or degenerate geometry.
                Adam
                  renderiza
                  Thanks everyone now SketchUp is not crashing! 😍
                  Here is that bit of code again revised...
                    if @animate
                      faces.each do |e|
                        mat = e.material
                        pt_array = [Geom;;Point3d.new(@speed_x ,@speed_y, 0), Geom;;Point3d.new(0, 0, 0)]
                        on_front = true
                  Again thanks everyone! πŸ‘
                    renderiza
                    Thank you guys so much could not do it without you guys!...Here is the latest update for Animatex; http://sketchucation.com/forums/viewtopic.php?f=323&t=52238
                    There is no scrambler for code so you guys can take a peek and will be grateful if you tell me any inefficiency in code so I can keep learning...cheers! πŸ‘
                    New Web Dialog::
                    http://s23.postimg.org/4i96v6fvf/animatex_dlg.jpg
