    Persistant crashing
    5 Posts 2 Posters 299 Views 2 Watching
    • opalO Offline
      opal
      Here's what I am doing
      load one component for scaling.
      draw a rectangle
      delete componant
      scale one side of that rectangle
      pick ANY other tool.. and I mean just choose it. Select.. move..push/pull, even zoom extends and
      splat
      5x now! It's making me crazy
        Does it crash if you do something different after deleting the component? Do you have to load the component to get it to crash? What if you purge unused components after you delete the component from the drawing space? does it crash then?
        • opalO Offline
          opal
          tested several of those suggestions.. seems I have an issue with scaling. Immediately after scale operation (fredoscale) splat - with or without components.. with or without purging.
          might be time to check for plugin updates
          thanks
            So it is FredoScale that you're using?
            What operating system?
            Since this isn't a SketchUp bug I'll move this post out into the sketchUp discussions where you'll get better coverage.
            • opalO Offline
              opal
              ok.. thanks and windows 7 ult
