    Help Finding a plugin if there is one
    6 Posts 2 Posters 471 Views 2 Watching
    • I Offline
      IAho
      Is there a plug-in so I can save my assembly one time rather than having to save it many times in the same drawing ?
      Is there a way I don't have to use so many scene's all the time, so that I can save straight to the assembly ?
      Thanks for any help.
      • mitcorbM Offline
        mitcorb
        Hi.
        Could you explain your use of the term "assembly"? Do you mean a Sketchup "group", or "component" or the entire model? Or do you mean a specific collection of groups or components? It might be helpful if you could attach an image or a sketch or the .skp file so that folks can help you. Your scenes question suggests several possible answers depending on what you want to accomplish.
        • I Offline
          IAho
          My language skills are poor, sorry .. but I will try
          attached is a picture that may help. I hope
          thanks for the help
          Workshop
          • mitcorbM Offline
            mitcorb
            Hi, IAHo:
            I think you are saying that you want to save all of those components at once. You can select them and make them one component if you desire. They will each retain their identities as separate components but members of the larger component.
            I am only guessing here:
            Perhaps you want to look into the use of Layers, and assign these components to a specific named layer and then use Scenes to manage views, visibility, and so forth?
            I am sorry I don't know your experience level in this program.
            Please do respond with more information. There are many here who can help you.
            And I apologize for my language skills not being so great in your language-- which is?
            I can only stumble along in those based on Latin. But if there is difficulty, you can also join this Forum hopefully in your native tongue.
            Please do update your User Profile. Often this is helpful to provide answers that are more relevant to your experience.
            EDIT: Also check this site: http://www.sketchup.com/intl/en/training/videos.html
            • I Offline
              IAho
              My job is to design the structure
              I plan steel structures
              my problem is controllability sub-assemblies, see Annexes
              the problem ..
              parts will be a lot
              scenes will be a lot of
              the solution is to
              save to your components directory
              and takes Layout.
              the question is, can I save the component at one time
              see Appendix
              thanks for the help
              building facades.pdf
              Steel frame.pdf
              • mitcorbM Offline
                mitcorb
                Hi, IAho:
                Since you mentioned plugin in your thread title, maybe tak2hata's Building Structure Tools? maybe not.
                What I said in my first reply still holds. When you insert all of those skp's of different parts of your assembly, they are defined as components in your working file. That is because a Sketchup component is basically a .skp file itself. Collecting a bunch of components and defining this collection as a component with a unique name will create an "assembly".
                Does this help?
