    How to distinguish face size
    11 Posts 6 Posters 920 Views 6 Watching
    • pingpinkP Offline
      pingpink
      Hi , I have some questions.
      I'm trying to distinguish face sizes with the part-number by using set_attribute( Generate part number and displaying colored faces) , and get_attribute ( Export in Excel ). But , I can't make same face size area to have same color , and count the pieces.
      What should I revise to make it works?
      Thanks so much
      <span class="syntaxdefault">def set_attribute<br /><br />    model </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />    model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start_operation</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'Colour by same area and dimensions'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    entities </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br />    face</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">    face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_attribute</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Attribute"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"Glass"</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">true</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    colors </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Color</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">names    <br />        attribute_name </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> colors</span><span class="syntaxkeyword">[</span><span class="syntaxdefault"> rand</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> colors</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length</span><span class="syntaxkeyword">-</span><span class="syntaxdefault">1 </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">        m </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">materials</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> attribute_name </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        m</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">color </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> attribute_name<br />        model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">          next unless e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">          e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> m<br />         <br />        </span><span class="syntaxkeyword">}</span><span class="syntaxdefault">    <br />          <br /></span><span class="syntaxcomment">### this gives the face your-attribute called Glass that is true<br /></span><span class="syntaxdefault">end<br /><br />def get_attribute<br /><br />    model </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />    entities </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br />    face</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">    context </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_attribute</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Attribute"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"Glass"</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    if context<br />      </span><span class="syntaxcomment">#===============#<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment">#  PART-NUMBER  # GL-01 , GL-02 , GL-03 , ....<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment">#===============#<br /></span><span class="syntaxdefault">        puts </span><span class="syntaxstring">"GL-01"<br /></span><span class="syntaxdefault">        <br />      </span><span class="syntaxcomment">#===============#<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment">#  DIMENSIONS   # <br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment">#===============#      <br /></span><span class="syntaxdefault">      <br />        glas </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">bounds<br />        puts </span><span class="syntaxstring">"Width ; #{(glas.width*(0.0254)).to_f.round_to(2).to_s }"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">+</span><span class="syntaxdefault"> </span><span class="syntaxstring">" m"<br /></span><span class="syntaxdefault">        puts </span><span class="syntaxstring">"Height ; #{(glas.depth*(0.0254)).to_f.round_to(2).to_s }"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">+</span><span class="syntaxdefault"> </span><span class="syntaxstring">" m"<br /></span><span class="syntaxdefault">        <br />      </span><span class="syntaxcomment">#===============#<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment">#   QUANTITY    # <br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment">#===============#<br /></span><span class="syntaxdefault">  <br />        num</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">0<br />        ss</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection<br />            if ss</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">                ents</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">ss</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_a<br />            else<br />                ents</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_a<br />            end</span><span class="syntaxcomment">#if<br /></span><span class="syntaxdefault">        defs</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definitions<br />        ents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">num</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">num</span><span class="syntaxkeyword">+(</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">)</span><span class="syntaxdefault">if e</span><span class="syntaxkeyword">.class==</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">        defs</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">d</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">        d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">        n</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">instances</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length<br />        num</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">num</span><span class="syntaxkeyword">+(</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">*</span><span class="syntaxdefault">n</span><span class="syntaxkeyword">)</span><span class="syntaxdefault">if e</span><span class="syntaxkeyword">.class==</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face<br />            </span><span class="syntaxkeyword">}</span><span class="syntaxdefault">    <br />        </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">        puts </span><span class="syntaxstring">"Quantity ; #{num}"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">+</span><span class="syntaxdefault"> </span><span class="syntaxstring">"  Pcs"<br /></span><span class="syntaxdefault">                <br />      </span><span class="syntaxcomment">#===============#<br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment">#     AREA       # <br /></span><span class="syntaxdefault">      </span><span class="syntaxcomment">#===============#<br /></span><span class="syntaxdefault">      <br />        area </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">area</span><span class="syntaxkeyword">*(</span><span class="syntaxdefault">0.00694444444</span><span class="syntaxkeyword">)).</span><span class="syntaxdefault">to_f</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">round_to</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">to_s <br />     <br />        </span><span class="syntaxcomment">#area = (face.area /(1.m*1.m)).to_f.round_to(2).to_s + " SQ.M"<br /><br /></span><span class="syntaxdefault">        puts </span><span class="syntaxstring">"Area ; #{area}"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">+</span><span class="syntaxdefault"> </span><span class="syntaxstring">" SQ.Ft"<br /></span><span class="syntaxdefault">       <br />     else<br />        puts </span><span class="syntaxstring">"This glass does not have Part-Number"<br /></span><span class="syntaxdefault">     end</span><span class="syntaxcomment">#if<br /></span><span class="syntaxdefault">     <br />  </span><span class="syntaxcomment">#return num<br /></span><span class="syntaxdefault">     </span><span class="syntaxcomment">#===============#<br /></span><span class="syntaxdefault">     </span><span class="syntaxcomment"># Export  Excel # <br /></span><span class="syntaxdefault">     </span><span class="syntaxcomment">#===============#     <br /></span><span class="syntaxkeyword">=</span><span class="syntaxdefault">begin         <br />    out_name </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"#{File.basename(model.path).split("</span><span class="syntaxkeyword">.</span><span class="syntaxstring">")[0]}"</span><span class="syntaxdefault"> <br />    if out_name </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> </span><span class="syntaxstring">''</span><span class="syntaxdefault"> then out_name </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">'Report'</span><span class="syntaxdefault"> <br />    out_name </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"#{out_name}_faceareas.xlsx"</span><span class="syntaxdefault"> <br /><br /><br />    unless </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">out_name </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">savepanel</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxstring">"Where shall I save the output?"</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"."</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> out_name </span><span class="syntaxkeyword">)).</span><span class="syntaxdefault">nil</span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> then <br /><br /> <br />        area_file </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> File</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault"> out_name </span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"w+"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> <br /><br /> <br />        if area_file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">nil</span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> then <br />            UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">messagebox</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxstring">'File error!'</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> <br />            return <br />        end <br /><br /><br />        face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each do </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">f</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> <br />            area_file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">puts</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxstring">"#{f.area}"</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> <br />            <br />        end <br />    else <br />        User aborted <br />    end <br /><br />    area_file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">close <br />end <br /></span><span class="syntaxkeyword">=</span><span class="syntaxdefault">end<br />end</span>
      • jolranJ Offline
        jolran
        Not sure about your rounding method ? round_to ?
        Float=>round can take a parameter in Ruby 1.9, not in Ruby 1.8.~
        Could be totally wrong here, but it look fishy to me. If I'm wrong (which we soon will see) I've at least learnt something new today..
          Notwithstanding some of the methods you are using to format strings - suggest you look up sprintf etc...
          An .xls file is 'binary' and it is specially encoded for Excel to read, as is the newer .xlsx file type.
          You on he other hand are writing plain text strings to a file.
          It will never work in Excel by writing a file like that.
          You have two choices...
          Change the file suffix to '.csv', this is a Comma-Separated-Variable format that will open in Excel - it will not have any formating.
          You will need to assemble a string including commas separators that you then 'puts' to the file; otherwise you'll have a single column of entries...
          You can link a csv file into an xls file dynamically so as you change the csv's contents you can update the xls's display; that way you can format the xls and just use the data from the csv export...
          OR if you are on PC you could learn how to access Excel using WIN32OLE.so - I have done it in the past - reading and writing xls files direct BUT it is much more convoluted... You can edit formats, cells and cells contents formulas etc... look up this crib http://davidsulc.com/blog/2011/03/27/using-ruby-and-win32ole-to-manipulate-excel/ there are several others if you Google...
          • pingpinkP Offline
            pingpink
            Thank you kindly jolran and TIG.
            @jolran , I always use round_to and it can run on SU 7,8.
            Do I have to change to be ' float ' ?
            I'm not expert in ruby.
            @TIG , I will study about the export which you suggested to me.
            I don't know how to do automatic part-numbers meanwhile changing each colored faces separately , then report sizes , pieces ,and area.
            I'm trying to figure it out.
              Then you have a plugin that modifies the base Float class. (which is a big no-no)
              If you try it with a plain vanilla installation of SketchUp you get an error:
              1.23456.round_to(2) Error: #<NoMethodError: (eval):894: undefined methodround_to' for 1.23456:Float>
              (eval):894`
              • jolranJ Offline
                jolran
                Listen to these two guys first and foremost. they know what they are talking about..
                In any case look up methods compatible with Ruby 1.8.6~7 . I think SU 7,8 use just about same Ruby versions..
                "The Pragmatic Programmer's Guide" should be relative to 1.8 I think, if you have missed that one by a chance. The "round" method is described there as well.
                Just bought a Ruby book and half of it was for Ruby 1.9 and up 😄
                  For example
                  sprintf("%.2f", 1.23456) 1.23
                  This is a String - which will be good for a text-file/report... but
                  sprintf("%.2f", 1.23456).to_f 1.23
                  Is a Float again if desired...
                  • K Offline
                    ktkoh
                    I have been looking at rounding calculated dimensions in my woodworking joint program and this is what I came up with. I only accept inches and millimeters as sketchup units and then round the calculations to the precision set for the active model. It is not very compact code but seems to work.
                    mod = Sketchup.active_model # Open model
                    ent = mod.entities # All entities in model
                    sel = mod.selection # Current selection
                    @num = 1.0
                    #UI.messagebox("Test Number = " + @num.to_s)
                    prompts = ["Test Number = "]
                    defaults = [@num.to_s]
                    results = inputbox prompts, defaults, "Test Round Function"
                    if !results then;Sketchup.send_action "selectSelectionTool;";return;end
                    @num = results[0].to_l
                    #Test Units
                    @opt_LEN_No = Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]
                    @opt_Format_No = Sketchup.active_model.options["UnitsOptions"]["LengthFormat"]
                    @opt_Precision_No = Sketchup.active_model.options["UnitsOptions"]["LengthPrecision"]
                    @opt_Precision_No = @opt_Precision_No.to_s
                    UI.messagebox("Precision = " + @opt_Precision_No)
                    case @opt_Precision_No
                        when "0"
                            if @opt_Format_No == 0 then @round = 1.0 end
                            if @opt_LEN_No == 2 then @round = 0.0393701 end
                            if @opt_Format_No == 3 then @round = 1.0 end
                        when "1"
                            if @opt_Format_No == 0 then @round = 0.1 end
                            if @opt_LEN_No == 2 then @round = 0.00393701 end
                            if @opt_Format_No == 3 then @round = 0.5 end
                        when "2"
                            if @opt_Format_No == 0 then @round = 0.01 end
                            if @opt_LEN_No == 2 then @round = 0.000393701 end
                            if @opt_Format_No == 3 then @round = 0.25 end
                        when "3"
                            if @opt_Format_No == 0 then @round = 0.001 end
                            if @opt_LEN_No == 2 then @round = 0.0000393701 end
                            if @opt_Format_No == 3 then @round = 0.125 end
                         when "4"
                            if @opt_Format_No == 0 then @round = 0.0001 end
                            if @opt_LEN_No == 2 then @round = 0.00000393701 end
                            if @opt_Format_No == 3 then @round = 0.0625 end
                         when "5"
                            if @opt_Format_No == 0 then @round = 0.00001 end
                            if @opt_LEN_No == 2 then @round = 0.000000393701 end
                            if @opt_Format_No == 3 then @round = 0.03125 end
                        when "6"
                             if @opt_Format_No == 0 then @round = 0.000001 end
                             if @opt_LEN_No == 2 then @round = 0.0000000393701 end
                             if @opt_Format_No == 3 then @round = 0.015625 end
                    end #case
                    UI.messagebox("Round To = " + @round.to_s)
                    @num_R = ((@num + (@round/2.0))/@round).to_i*@round
                    UI.messagebox(@num.to_s + " Round to  " + @round.to_l.to_s + " = " + @num_R.to_l.to_s)
                    Sketchup.active_model.entities.add_line [@num_R,0,0],[@num_R,@num_R,0]
                    Keith
                      @pingpig
                      I think you miss the point a bit. 😕
                      Float.round_to()
                      does not exist as a standard method for the version of Ruby that ships with SketchUp.
                      Therefore is you are not making it yourself by adding to the standard methods - which is generally advised against, and alternative ways are recommended - then you must have another script loading that creates that method. Thus if you don't have that script loading, or another user of your script doesn't have it the ' round_to' method will break and the script will fail with errors...
                      The example you posted extends/modifies the Float base class in a number of ways [unwisely] - some methods are not needed - e.g. Float.abs - because these come built-in to Ruby ! Sketchup also adds its own additional functions to convert to and from radians, and numeric ways of dealing with lengths etc... Please read the API documents... AND some general Ruby help publications... Dan Rathbun has provided several good threads and links at SCF that will help you...
                      My example of the ' sprintf()' uses a simple built-in Ruby method that is used for formating floats in several ways - typically into strings at a fixed d.p., although you can convert that back into a 'rounded' float if desired using .to_f...
                      • Dan RathbunD Offline
                        Dan Rathbun
                        The post of that modification of Fixnum should be removed! (It is very poorly done.. overrides base methods, some of which return float instead of integer.)
                        I'm not here much anymore.
                        • pingpinkP Offline
                          pingpink
                          Thank you very much !
                          Actually , I refer "round_to" in a class Fixnum below my main codes. I don't see any error.
                          It's my new knowledge about sprintf("%.2f", 1.23456)
                          [ruby]class Fixnum
                            def abs
                              rx = self
                          	if rx < 0
                          	  rx = -rx
                              return rx
                            def to_meter
                              ufactor = 1.m
                          	rx = (self) / ufactor
                          	return rx
                            def round_to(x)
                              (self * 10**x).round.to_f / 10**x
                            def ceil_to(x)
                              (self * 10**x).ceil.to_f / 10**x
                            def floor_to(x)
                              (self * 10**x).floor.to_f / 10**x
                            def rad_to_deg
                              (self / Math;;PI) * 180.0
                            def deg_to_rad
                              (self * Math;;PI) / 180.0
                            def comma_format
                              s = self.to_s
                              if s.include? ?.
                                  pre, post = s.split '.'
                                  "#{pre.reverse.gsub( /\d{3}(?=\d)/, '\&,' ).reverse}.#{post}"
                              else
                                  s.reverse.gsub( /\d{3}(?=\d)/, '\&,' ).reverse
                          [/ruby][/code]
