    OnKeyDown not working when Web dlg is focuse...why?
    6 Posts 4 Posters 529 Views 4 Watching
    • renderizaR Offline
      renderiza
      I was wondering what some of you do in a situation where because the web dlg is focuse the onKeyDown function does not work. Maybe use both javascript keys when web dlg is focused and onKeyDown when web dlg is not focused at the same time?
      Maybe in the future SketchUp should support onKeyDown with web dlg focused?...I am not sure.
      cheers! πŸ‘
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        You mean the Tool event doesn't respond when WebDialog is focused?
        It's something which is inherit in the design of the OS. The active window is the one that receives the key-strokes.
        However, I do wish it was possible to make WebDialog act like floating toolbar-windows which returns focus to the main SU window.
          renderiza
          Very good idea!
            Perhaps in your html
            <element onkeypress="window.blur">
            the 'element' would typically be 'body' ?
            You can use/choose:
            onkeydown onkeypress onkeyup
            You could of course write a customized js to run 'onkeypress=' instead and that could do 'window.blur' IF the 'key-press' returned specific values, or other actions otherwise... event.keyCode return sthe UTF key-code - I think πŸ˜•
            Have a play around...
              renderiza
              Thanks TIG I will try that eventually.
                driven
                some reading http://unixpapa.com/js/key.html
                it's title
                JavaScript Madness: Keyboard Events
                trying to get my head around it at the moment...
