    Temperature gradient on Sketchup 8.0
    14 Posts 5 Posters 1.8k Views 5 Watching
      diogofsousa92
      Hi everyone,
      i'm a new user of google sketchup. I'm working in a company and they told me to do the laboratory where i am in 3D. So far so good, but now they told me to do the temperature gradient of the room. I wanna know if is possible do it on skhetchup.
      Please help me!
      Best Regards,
      Diogo Sousa
      • beginnerB Offline
        beginner
        Hi diogofsousa92,
        I don't know how to do it but, temperature and light have similarities in the way how you draw the gradients / distribution.
        There are few plugins for SketchUp which are dealing with light and energy 'Element'.
        I can only assume - if this is possible with light and energy it would be possible with temperature.
        Temperature could be more trickier (more external factors could disturb the distribution) but, some basic modelling should be possible.
        Just a thought...
        Look for Analysis Tools for SketchUp.
        Regards, SU 'beginner'
        • N Offline
          notareal
          Perhaps something like EnergyPlus is usable?
          http://apps1.eere.energy.gov/buildings/energyplus/
            diogofsousa92
            @beginner said:
            Hi diogofsousa92,
            Just a thought...
            The idea is using some data loggers in the lab to record the temperatures. After that, i have to describe the variation of temperature in function of time (data/hour).
            The energy is not important for the case but thank you for your quick reply.
            Best regards,
            Diogo Sousa
              diogofsousa92
              I already knew that plugin but is not what i need. The EnergyPlus is usefull when you have your house/room, but my laboratory is underground, so the sun is not important for the case. I only have in lab HVAC controllated.
              Best regards,
              Diogo Sousa
              • beginnerB Offline
                beginner
                Hi diogofsousa92,
                Again, I don't know how to do it yet but, I try to follow your assignment...
                You said that you have data loggers:
                1. What kind of data do you collect (just temperature over time)?
                2. What kind of data format it is (*.csv, *.xls)?
                3. What kind of graph do you want to see in SketchUp (2D - where X is the time and Y is the temperature)?
                4. Do you have to show the temperature distribution within a room/shape? - I'm just thinking out loud here...
                If this is the case it is almost like a 2D point cloud but, it could me more fun - you could create 3D point cloud...Easily done in SketchUp.
                You could use:
                X axis = as a time (24 hours),
                Y axis = as a day (365 days)
                Z axis = as a temperature (whatever you read from your loggers in Excel)
                Each logger would produce separate graph...
                You will get surface...which you could slice and colour with different temperature thresholds and slice again day-by-day etc - I see that as 'terrain with contours' with fixed/predicted plan area.
                Have a look at point cloud and terrain topics in SU.
                PS. I think it could be beautifully presented in SketchUp
                  diogofsousa92
                  @beginner said:
                  Hi diogofsousa92,
                  You could use:
                  Hi beginner,
                  i think that is just what i looking for, but how i can do it?
                  1. Yes, i collect temperature over time (time is data and time "yyyy-mm-dd hh:mm")
                  2. The file is .xls
                  3. What i realy wanna see is my graphic moving when time is passing, i mean, as time progresses, the temperature will range.
                  Thank you
                  • DavidBoulderD Offline
                    DavidBoulder
                    You should be able to create cubes that represent the data loggers, and can use color range to indicate temperature. You can use SketchUp's date/time slider and then change colors on the fly from an external data source.
                    Both the legacy and beta OpenStudio plugin do this with the SQL fie that EnergyPlus outputs. It was always pretty sluggish but we are dealing with annual time series temperatures for every surface in the building. Your data set should be more manageable.
                    I'm on the bus so couldn't find video showing this with temperature, but this one is showing fraction of surafce that is sunlit and a given time.
                    http://youtu.be/TI_uygHShL0
                    David Goldwasser
                    OpenStudio Developer
                    • beginnerB Offline
                      beginner
                      Hi diogofsousa92
                      Hmmm...
                      Now the task need to have some animation - I did some simple setting out - you can export to *.avi or sequence of bitmaps if needed.
                      Hava a look at the attached sample.
                      PS. Next step - we will import the *.xls loggers data to SU (first thought - I would use AutoCAD to the create the cloud and the import to SU - any other thoughts?).
                      SUF-TemperatureGradient.skp
                        diogofsousa92
                        I think that's not what i pretend. I did some research and i found two interesting software: Solidworks and Autodesk Simulation CFD. But i dont know if i can import my *.xls files.
                        My thought is:
                        1- Import my 3D model into one of this softwares
                        2- Chose points in my model where my data loggers record the temperature
                        3- On that points, import the *.xls files with the values of temperatures
                        4- Hopefully see the multiples temperatures in my lab, something like that: http://www.youtube.com/watch?v=CxHVLqUYYL8
                        or
                          You can only import XLS files directly into a SKP if you were to write a custom PC tool to read the XLS file binary data using Win32ole.so linked into Ruby
                          However, you can save_as XLS files from within Excel, as CSV [Comma Separated Variable text files] which are easily read in Ruby and the data converted into geometry. There are many examples of this - the most common being importing XYZ data via CSVs for making terrain meshes- one point per line [1.2,3.4,5.6] etc...
                            diogofsousa92
                            But i want export my 3D model Sketchup to another software, and then, import my *.xls files on that software
                              That wasn't clear.
                              What format do you want to use when exporting the SKP ?
                              I had understood that you wanted to import data into the SKP to get a visual representation of temperature-gradients etc.
                              If that's not the case then all you need s a way of exporting the SKP in a format that this 'unnamed other application' can use ??
                                diogofsousa92
                                I tried make terrain meshes but is not what i need. So the only way is exporting the SKP to another modeling software, like solidworks, autodesk simulation cfd and now Xflow CFD
