    Transparency becomes white after rendering
    renderpluginsextensions
    5 Posts 4 Posters 363 Views 4 Watching
      brianlhs
      The edge of the tree is transparent before rendering. Anyone can teach me how to solve this problem? Thanks!
      • O Offline
        Openspaces
        In your material editor, under the diffuse channel, Check the "use colour texture for transparancy" box.
        i hope this helps you
        • chonC Offline
          chon
          Hello,
          True if your Bitmap is saved in PNG...
          SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win10-64Bits
            brianlhs
            @chon said:
            Hello,
            Thank you so much! I'll try later
            • Z Offline
              Zylescozar19
              Tick the "Use color texture as transparency" in the Diffuse layer of the material.
