Transparency becomes white after rendering
The edge of the tree is transparent before rendering. Anyone can teach me how to solve this problem? Thanks!
In your material editor, under the diffuse channel, Check the "use colour texture for transparancy" box.
i hope this helps you
Hello,
True if your Bitmap is saved in PNG...
@chon said:
Hello,
Thank you so much! I'll try later
Tick the "Use color texture as transparency" in the Diffuse layer of the material.
