Smooth cause weird shading
Hi, everyone
I'm just working on a model which involves huge of arc and curves, so smoothing becomes quite frequently used to make surface look good. Problem is after smoothing some weird shading happens while sometimes it doesn't.
See red highlighted area for this strange shading in my attached picture below.
I searched forum and didn't find a better solution. Any help is thankful.
JERRY
Instead of using Smooth/Soften, use Hide on that edge and see if it's different.
Is the edge of that texture image dark? Can you post that texture image?
Hi, Dave. After a zoooooom, i found a little stray line intersecting with two model line. Problem solved. sorry to cause any trouble here.
No trouble caused. Glad you got it worked out.
Register LoginAdvertisement
