    Smooth cause weird shading
    4 Posts 2 Posters 288 Views 2 Watching
      jerrywz68
      Hi, everyone
      I'm just working on a model which involves huge of arc and curves, so smoothing becomes quite frequently used to make surface look good. Problem is after smoothing some weird shading happens while sometimes it doesn't.
      See red highlighted area for this strange shading in my attached picture below.
      I searched forum and didn't find a better solution. Any help is thankful.
      JERRY
      weird shading after smoothing (Option+E on mac)
        Instead of using Smooth/Soften, use Hide on that edge and see if it's different.
        Is the edge of that texture image dark? Can you post that texture image?
          jerrywz68
          Hi, Dave. After a zoooooom, i found a little stray line intersecting with two model line. Problem solved. sorry to cause any trouble here.
            No trouble caused. Glad you got it worked out.
