    Make face plugins
    5 Posts 3 Posters 9.5k Views 3 Watching
    • G Offline
      GraemeDunne
      Hi. New to Sketch up. I am looking for a plugin to make faces on line drawings. So if I delete a line and the face disappears I can put it back. Also is there a plugin for making curved faces? Any links would be helpful. Thanks.
        There are several 'make-face' tools around.
        Search the forums, and of course the Plugins lists themselves...
        There's even one in the 'utilities' extension's tool shipped with SketchUp...
        If by 'curved faces' you mean a 'curved surface' then you can hand-stitch triangular faces between pairs of edges, to form a surface [smooth it later] OR to make more complex surfaces between curves profiles/rails etc, then look at my Extrude tools, or Fredo's CurviLoft etc...
          and with thickness from a curvated surface Joint Push Pull by Fredo6 can help you! πŸ˜‰
          • G Offline
            GraemeDunne
            That utility does not seem to work. I can not seem to find the MakeFace plugin by Todd.
              Todd Burch's stuff is mainly on Smustard.com.
              My similar tool is at SCF [here!]
