    SketchUp was unable to install the Extension
    2 Posts 2 Posters 673 Views 2 Watching
    • S
      skytrooper
      Hi .Will someone help me. I just tryed to install the LibFredo6 to SketchUp and got this message SketchUp was unable to install the Extension you have chosen for unknown reason
      Consult your Extension's documentation for additional help
      I dont have a Extension's documentation or I dont understand what they mean will you help me
      Thank you
      skytrooper
      • TIGT
        Chances are you do not have sufficient access-rights to add/change files/subfolders in your SketchUp Plugins folder...
        By default Windows will probably have limited you to have Read-only access, because the Plugins folder is within the 'Program Files' folder 'tree'... BUT you will need Read/Write [FULL] rights to add/change its files/folder...
        So... you need to find your Plugins folder's icon...***
        Select it, right-click > context-menu > Properties > Security > Edit...
        Ensure everyone/every-group listed [of course including yourself] have FULL rights to that folder...
        You might have to have admin-rights to change this...
        Ensure that these FULL rights 'trickle-down' to all of its contained files/subfolders...
        Also check that the owner of the folder has similar rights, if not perhaps try changing its owner to be 'you' ?
        ***You are on a PC so depending on your OS your Plugins folder should be in
        C:/Program Files/../Sketchup../
        But copy+paste+<enter> this code into the Ruby Console if you are not completely sure...
        Sketchup.find_support_file('Plugins')
        it'll return somethings like...
        C:/Program Files/Google/Google SketchUp 8/Plugins
        Other related SketchUp folders that you might want to write to from time to time... include Components, Materials and Styles... which should also have FULL permissions set...
