    Second bounce renders black in final image
    renderpluginsextensions
    2 Posts 2 Posters 592 Views 2 Watching
    • P Offline
      PDSRDM
      I'm trying to render and image using Vray for SU8 and in the final pass everything that does not have direct lighting renders black. In the first prepass(es?) however, I can clearly see vray is calculating everything ok. As far as I know I am using the exact same settings I've been using on other renders before that went fine. (see attachments)
      Any clue of what is going on? I have a deadline coming up and this is stressing me out! πŸŽ‰ πŸ˜‰
      Thanks!
      • panixiaP Offline
        panixia
        make you sure that in the "Indirect Illumination" tab the GI -> On box is checked
