    DC not working Help?
    7 Posts 3 Posters 1.0k Views 3 Watching
    • sfto1S
      sfto1
      I downloaded the attached DC from 3D Warehouse. The description on the component stated it is editable for width, but when I try to edit the width (or anything), SU says there are no options to choose from on this component. Since I am a newbie regarding DCs, can someone please double check if this component has any options? I cannot tell from the component attribute box whether this is a working DC.
      Thanks in advance.
      tall open.skp
      • J
        Jim
        Try importing the .skp rather then opening it.
        • sfto1S
          sfto1
          When I try to import model, I get the following error
          Cannot create a recursively defined model or component!
          I imported a cabinet component from "Kraftmaid" and it did work. Now wondering if Tall Open Component is buggy.
          Did you get this particular component to work?
          • J
            Jim
            I downloaded the component and imported it no problem.
            • sfto1S
              sfto1
              Thanks Jim,
              I closed SU and re-opened. Imported file and it worked fine.
              • BoxB
                Just for future reference, this error sounds like you tried to import the component into itself.
                In the same way you can't paste a component into itself.
                As in:
                create a box and make it a component.
                Select the component and copy it.
                Open the component to edit and Paste in place.
                You should get the same error.
                • sfto1S
                  sfto1
                  Hi Box,
                  Here is what I did. I downloaded file and opened it. I had trouble as I first posted with the component having no component options. I received a comment that I should import it, not open it.
                  So when I tried that, I deleted the component from the screen and imported the file. Yes indeed, I imported the component into itself. Arrgghhh!!!!!
                  So, I am now understanding that DCs must be imported in order for component options to be activated. Is that correct?
                  and thanks for the heads up regarding not pasting a component into itself. 😳
