    Photomatch question
    11 Posts 7 Posters 2.2k Views 7 Watching
    • cottyC Offline
      cotty
      Is there a way to use the matched photo as a "normal" picture after the match, e.g. for rendering (background picture)?
      my SketchUp gallery
      • Wo3DanW Offline
        Wo3Dan
        @cotty said:
        Is there a way to use the matched photo as a "normal" picture after the match, e.g. for rendering(background picture)?
        A bit confusing. Is it for rendering the building (right click and select the rendering option) or is it meant to be used as background?
        • cottyC Offline
          cotty
          The background usage...
          I hoped for something like this: rightclick and choose explode, unmatch, delock, ... so that the image is no longer a matched photo object.
          my SketchUp gallery
          • Wo3DanW Offline
            Wo3Dan
            Speechless 😐
            I see no other way than a clumsy one where you try to import again and manipulate the image.
            Maybe a plugin request for one that "grabs" the matched image, to be used 'as image' or as texture. How would you deal with the perspective issue in the background of such an image?
            Isn't it only useful for one camera position.
            Sorry for poor answer so far.
            • cottyC Offline
              cotty
              Yes, but one is better than none 😉
              (Original question with picture example)
              my SketchUp gallery
                Cotty, I think what you want is a scene with the exact camera angle and FOV as the PM scene but without the PM "functions", right? Without the PM background (e.g. with a single, white background to PS it away and replace it with the photo used in the PM scene after rendering) or something...
                So there are workarounds...
                1. make your photomatch...
                2. now navigate away a bit and create a new scene
                3. delete the photomatch scene
                4. use the Camera (menu) > Previous to get back to the same camera where the PM was taken (but without the PM background and all).
                5. create a scene here to replicate it.
                  If this is not what you meant, sorry for wasting your time...
                • olisheaO Offline
                  olishea
                  Cotty, I know what you mean. No simple way of doing it. I racked my brain for hours last year trying to achieve it. Basically I just had to render my model then open up the background in PS at same height as SU viewport.
                  The render can then be composited straight on top at the same resolution. You can of course supersample the background by making it 2x viewport height and then reducing by 50% for the render. 😉
                  Can you add a background in your render engine? If so you can automatically add the original photo behind the render.
                  oli
                  • N Offline
                    numerobis
                    couldn't you add a plane behind your PM-model, hide your model and project the picture on the plane?
                    • olisheaO Offline
                      olishea
                      The plane skews into perspective/FOV of the Photo Match. Hard to match.
                      oli
                      • pbacotP Offline
                        Maybe a camera tool can create a plane that is correct to project onto.
                        • broomstickB Offline
                          broomstick
                          There is actually a plugin for that, but I forget the name right now..
