    A post processing experiment
    20 Posts 13 Posters 3.3k Views 13 Watching
    • hellnbakH
      hellnbak
      Never really done any post processing, mainly because it seemed pointless without first rendering the model. Well, I still don't render (yet) but figured I'd give it a try with a model I'm working on.
      The model itself isn't finished yet. It's Preston's Station in Belle Plaine, Iowa. I knew at the outset that the model itself would still look like just a SU model and wouldn't blend in with the setting like it should, so I didn't put a lot of effort into it, just added some grass, some trees and a background (moved it into the country instead of in town like the real thing).
      Anyhow thought I would throw it on here to see what you thought.
      • andybotA
        andybot
        Looks good Steve! Your texturing is great, but I think the most CG thing about it is your sharp shadows. That's where rendering helps, you can give a softer edge to your shadows, plus the lighting under the eaves will have a more gradual fade to darker with GI lighting, rather than just the straight cutoff that you get with the SU shadows.
        Otherwise, in terms of your PP, it does blend in quite nicely.
        • olisheaO
          olishea
          cant believe you dont render lol, it looks great! sun is on wrong side of sky though....thats my only niggle really! πŸ‘ reminds me of american pickers!
          oli
          • hellnbakH
            hellnbak
            Thanks for the critique, Andy! Yeah, I know the shadows suck, much too sharp and uniform. I played around with it a bit, just the side, not the front. I think it looks a little better. Or it sucks a little less. Played around with the levels some too, and added some vegetation.
            I'm trying to relearn PS from when I last used it, years ago. My brain has a retention factor of minus 75. Have to wear a label pinned to my clothes with my name and address on it πŸ˜•
            Should have mentioned that it is reflecting off a very large and shiny UFO off to the left, just out of sight. Trust me πŸ˜‰
              Very convincing!
              • hellnbakH
                hellnbak
                Thanks Pilou. I know it's nothing great, but it was just an experiment. Actually I don't know that I'll even finish the model, sorta lost interest in it and have moved on to other things. But hey, it was interesting, and I did learn a couple of things.
                • Bryan KB
                  Zerk. πŸ‘
                  • ely862meE
                    ely862me
                    Are you sure you DON'T RENDER ? πŸ˜„
                    Great outcome !!
                    Elisei (sketchupper)
                    Come and See EliseiDesign
                    • pbacotP
                      At some point you just have to admit you don't need no stinkin render engine!
                      Shadows on the low eave look great.
                      Something you might want to play with is exporting your shadows separately--or is that what you did?
                      • hellnbakH
                        hellnbak
                        Thanks, guys.
                        If you mean using a monochrome shot with just the shadows, yeah, I did try that. Couldn't get it to work very well so I ended up using another, more involved, method. Like I said, I learned a few things playing with this. But I doubt I'll ever try it again, the results just aren't worth the effort. But thanks for the input, much appreciated.
                        • DanielD
                          Daniel
                          They both look outstanding, Steve.
                          My avatar is an anachronism.
                          • J
                            jpalm32
                            Grass is super. I can't do grass, so I stay indoors.
                            You need more signs though.
                            • hellnbakH
                              hellnbak
                              Thanks. The second one is an improvement, but it still looks like a SU model. I might work on it some more sometime, maybe if I figure out the necessary techniques I can get there. Maybe.
                              Thanks John. Actually the grass was pretty easy (once you find the right photo)
                              More signs huh. Well, there are a lot more on the other side...2013-02-08_081540.jpg
                              and the barn right next to it has a couple too...
                              George Preston collected these signs and a lot of other gas station memorabilia for a lot of years. Both buildings are full on the inside, too.
                              • DanielD
                                Daniel
                                I think I prefer the first one, as it is in the sunlight, but they both look great. I think your being too hard on yourself - they look rendered to me, even if they are "just" SU.
                                • omiKronO
                                  omiKron
                                  Gosh... If I didn't have read the title I'd thought it's a picture of the real thing, except for the pictures which you already posted. Very well done !
                                  • M
                                    m625
                                    Looks amazing for being directly from SU and texture work! I'm a noob at modelling but have been working in photoshop for quite a few years, would you mind if I gave your model a go in photoshop?
                                    • hellnbakH
                                      hellnbak
                                      Thanks, Nicholas, much appreciated. I've pretty much given up on the post processing, concentrating now on just making the SU model look halfway decent. Obviously a long way to go yet, the grass is a real problem, but I'm working on some ideas that hopefully will help.
                                      Thanks. No, I would have no objections to you, or anyone else, giving it a go. But, the model itself is pretty large, over 40mb because of all the signs and textures, plus it's not finished yet (need to do the gas pumps, some more signs to add to the right side to make it accurate, etc), so you would have to work from 2D exports of the model. Don't know if that would work for you, and don't know what all you would want for this, maybe a shot with shadows, without shadows, just shadows? I could also include the photos I used for the road, grass and background. Just let me know what you need. I'm sure you could do a better job than me, but then I'm still trying to figure out Photoshop. Hell of a program but very complex. Got some good books from Amazon that I'm studying but my brain is sooo tired πŸ˜’
                                      • J
                                        jpalm32
                                        Sick!
                                        The sixth brick from the back on the second layer needs some work.
                                        So there!
                                        How did you get so good, so fast?
                                        • tinanneT
                                          tinanne
                                          Looks fantastic! I really like the second one.
                                          Executive Director : American Society of Architectural Illustrators
                                          AIP 30 Competition opens soon. ASAI.org
                                          Architectural Rendering
                                          • okomtaO
                                            okomta
                                            i like to use my glasses,,or my eyes get more minus,,,:D
                                            you must be crazy man,,,it's oke,, no,,no,,i mean,,it's amazing,,no more then that,, can not talk,,,speechless..πŸ˜„
