    [Plugin] Face2Frame - Updated 27-Mar-2014
    66 Posts 19 Posters 63.7k Views 19 Watching
      Also post your option settings - it might be a units issue ?
      • KrisidiousK Offline
        Krisidious
        And what version of OS and SU are you running?
        By: Kristoff Rand
          mics_54
          question regarding this tool...whats the edge tool, CorG tool and Misc tool?
          Did I miss something?
          Nice framer though.
          • sdmitchS Offline
            sdmitch
            Nice framer though.
            No you didn't miss anything. I created the various sub-menus as a way of seperating the vari0us plugins of mine.
            http://sdmitch.blogspot.com/
            • sdmitchS Offline
              sdmitch
              @trimguy66 said:
              I get the same results, if I select an option, and then hit enter, or not make any selections at all.
              Please open the Ruby Console and then run the plugin. An error is occurring and this will tell me what it is.
                mics_54
                Nice blog! You have so many plugins! You now have the dubious distinction of being in my favorites under SU Ruby!
                  Krisidious
                  He's addicted to the coding challenge... He cannot resist a challenge.
                  By: Kristoff Rand
                  • O Offline
                    OSN58
                    I have this error
                      mwm5053
                      Try downloading and installing again you shouldn't be getting that.
                      2011 iMac
                      SU 2015 Pro, 2017 Make
                      V2 Twilight
                      macOS Sierra 10.12.5
                        mics_54
                        LUCKY ME ! 😍
                          trimguy66
                          Thanks for all the replies !!
                          I uninstalled the plugin, and then reinstalled, by saving to my desktop and then dropping in to my plugins folder. I am still getting the same results.
                          I am running Windows 7 / SU 8
                          I haven't tried removing all my other plugins, and restarting SU yet.
                          I am hoping that the ruby console will shed some light on my problem, before I go through removing all the plugins.
                          Thanks,
                          Wayne
                            Wayne
                            You have helpfully posted the RC error message BUT you have scrolled it, so the most important lines telling us what has just happened are missing. 😒
                            Could you recreate the error and post the entire error message again.
                            Once we know what the error says then sdmitch can probably go 💭 and see what to trap/fix...
                            I doubt very much it is a clash - more likely a simply coding error that occurs when particular parameters are chosen for a certain form of face etc... I'd expect it to be relatively easy to fix once the full RC error is known
                              Don't worry about the RC message...
                              I now see that an RC screenshot that was posted earlier shows the error to be in line #433...
                              pts<<p.offset(xa,dx/2).offset(ya,-dy).offset(za,(dx*@tpcnt+0.01)***sign**(v.z))
                              The method ' sign' is not defined in the tool's code and it's not a standard Ruby method either BUT it is defined in DC stuff... so perhaps users with the DC extension loaded will get it working OK anyway... or maybe another tool that not all users have is making it ? No unencrypted script is making it, so it must be an rbs file ?
                              It is only called once in the whole file...
                              The way to find the 'sign' of a value would be work for everyone as:
                              ...*((v.z)<=>0)
                              OR you could add a new method into this tool's code, so if you use it more than once
                              def sign(n=0)
                                return n<=>0
                              Usage: *sign(n)
                              Sdmitch to fix !
                              It's easily sorted...
                                trimguy66
                                Tig,
                                Thanks for your response, but I must admit coding is greek to this carpenter, I did attach a shot of the ruby console,scrolled in the proper position, in case it helps any.
                                I also added a shot of my plugin folder, to see if anything in there would help.
                                Thanks for everyone's help
                                Wayne
                                  That is the 'sign' error.
                                  Which means for some reason you do not have the 'sign' function added to Ruby by some other tool...
                                  It's easily fixed by editing the script at line #433.
                                  I have PM'd you [and Sdmitch] a working copy...
                                  BUT Sdmitch ought to fix it officially and post an update...
                                  • sdmitchS Offline
                                    sdmitch
                                    Sorry about the sign function problem that some have experienced. It never was a problem for me.
                                    A new version with TIG's fix has been posted.
                                      trimguy66
                                      Thank You sdmitch and TIG, the updated plugin work perfectly. 😍
                                      This place is such a wealth of knowledge and sharing!!!
                                      Now off to sdmitch's blog, to check out some of the very cool sounding plugins........
                                      Have A Great Day!!!!!
                                      Wayne
                                        Glad it's fixed. 😄
                                        😕 I've never come across this ' sign()' method before, although I can confirm that I have it auto-loaded into my Sketchup Ruby, even without DCs loading, and there's no 'sign' of it in any RB scripts I have that I've grepped - so I suspect an unidentified RBS file adds it, and if a user doesn't have that loading then they are screwed...
                                        I'd be interested to learn where ' sign()' originates...
                                        Meanwhile using the 'comparator' n<=>0 returns either 0, 1 or -1: which, when used with * effectively uses the 'sign' of the number 'n' in a calculation, without passing its real numerical 'value'.
                                        • sdmitchS Offline
                                          sdmitch
                                          I'm really not 100% sure where I found the sign function but I believe it was in the Ruby Console. Apparently I typed something like sign(-5) and it returned -1 so I assumed that it was a common function. I do have Ruby 1.8.6 installed so maybe that's why it works for me.
                                            I too get sign() in the RC... but with a standard SUp-Ruby only installation and DCs etc disabled I still get it.
                                            And it's not deined in any .rb files I have loading...
                                            So I must assume that there a .rbs file loading from somewhere that adds the global method...
                                            The alternative 'standard' way of n<=>0 is easy enough though...
                                            Another one that sometimes trips up scripters is group.definition [which is needed for adding instances of a group into another entities context etc, when 'copying' or 'moving' it to mimic Copy/Cut/Paste_In_Place...] - the method component_instance.definition does return the component's definition and some 3rd party tools add group.definition to the mix... but if you use that method and the recipient of your script hasn't got the other 3rd party script that adds it, then they'll get errors. The 'safe' way is to use group.entities.parent which returns that group's definition properly...
                                            • 2 / 4
