    Twisted and curving path
    21 Posts 8 Posters 4.0k Views 8 Watching
      alcohorse
      Hi all
      I've not posted in a long time but find myself stumped on my current project. I am trying to model a twisted form based on Thomas Heatherwicks benches at blue carpet square in Newcastle:[attachment=4:1i9qena4]<!-- ia4 -->NewcastleBlueCarpet.jpg<!-- ia4 -->[/attachment:1i9qena4]
      I have drawn 2 paths with a rectangular profile at the start but having spent the day trying to get curviloft to work using the 'skinning of shapes - loft junctions following 2 paths' tool. Unfortunately, I cannot get curviloft create solid, with depth. I did manage to get it to create one face of the desired form as shown below....
      [attachment=3:1i9qena4]<!-- ia3 -->FOLDED STAIR SURFACE.jpg<!-- ia3 -->[/attachment:1i9qena4]
      [attachment=2:1i9qena4]<!-- ia2 -->FOLDED STAIR SURFACE 2.jpg<!-- ia2 -->[/attachment:1i9qena4]
      So, it seams it could probably be done. I even used the joint push pull tool on this surface to make the solid but this is not ideal! Irritatingly with all the testing I cant recall how I did made this surface with curviloft (what linework was clicked and in which order)! 😞 I think I clicked just one side or one pair of sides of the rectangular profile as well as the paths but I cant get it to repeat the result.
      I have achieved the desired form in rhino and imported it into SU as shown below:
      [attachment=1:1i9qena4]<!-- ia1 -->FOLDED STAIR RHINO.jpg<!-- ia1 -->[/attachment:1i9qena4]
      [attachment=0:1i9qena4]<!-- ia0 -->FOLDED STAIR RHINO 2.jpg<!-- ia0 -->[/attachment:1i9qena4]
      I am not good with rhino however and it would be great if I could cut it out of my workflow for this project and just get curviloft to work in the same way. I'm just hoping to use this shape/principle to create a feature staircase so would really appreciate any help!
      Thanks!
      Surface created with curviloft...somehow!
      Reverse angle
      Imported from Rhino
      Reverse angle
        alcohorse
        Sorry, original attachment failed....
        The bench I am trying to replicate
          alcohorse
          Sorry - can now create the single surface again - select paths with just lines joining them at either end, then double click in middle (as per instructions at start of curviloft thread - d'oh). Unfortunately this still doesnt help me produce the same form with some thickness/depth in SU 😞
            Joint Push/Pull?
            • BoxB Offline
              If you could post a .skp with just the curves you want to use. After all, it's not the curve creation you want help with.
              • gillesG Offline
                gilles
                A one minute work,FredoScale bend tool:
                • V Offline
                  Vicspa
                  That would be my suggestion too, thanks Gilles. 👍
                  • mitcorbM Offline
                    mitcorb
                    This made me go looking in the Plugins Index.
                    Jim Foltz's Simple Shell
                    ThomThom's Shell
                      alcohorse
                      Thanks gilles thats great! Did try using a combination of twist and bend but wasnt sure where to apply them or the lengths of the axis. Any chance of a quick step by step otherwise perhaps ill look up the fredo manual/tut vids. Cheers for demonstrating how ridiculously simple this should be!
                      • gillesG Offline
                        gilles
                        Here we go:
                        FredoScale: http://sketchucation.com/forums/viewtopic.php?t=17948#p144180
                        Radial bend_V6.skp
                          alcohorse
                          Thanks Gilles - that is amazing! I will take a look at it later and hopefully can kick on from there - thank you so much!
                          • DareDevilD Offline
                            DareDevil
                            👍 👍 @ Gilles
                            My way use Shape Bender. Just take care the two pathes must have the same length.
                            • gillesG Offline
                              gilles
                              Yes, I use it to, but if you have multiple bend.
                                DareDevil
                                In this case, FredoScale won !! 😆
                                  alcohorse
                                  @daredevil said:
                                  :thumb: 👍 @ Gilles
                                  [attachment=0:3gv2f0sd]<!-- ia0 -->bend.jpg<!-- ia0 -->[/attachment:3gv2f0sd]
                                  Thanks DD, I'm not familiar with that plugin but will give it a try too. Thanks for all your help guys!
                                    alcohorse
                                    Thanks to everyone for all your help. Below are some images showing a basic model demonstrating the principle of the stair I am aiming to create. I have created a star along the original rectangle as modelled by gilles, and then followed the procedure to bend it.
                                    I actually want the length after the bend to be at 90 degrees to the original length, but raking down at an incline (say 45 degrees the purpose of this test). I have gone through a number of attempts to bend this 'stair' back up from its vertical position. Any thoughts on how to achieve this in a way that achieves a graduated rescaling around the 'fold'? Alternatively should I be looking to alter the original transformation to arrive at the form I am after. I fear if this is the case then it may come back to basic maths which Gilles has already demonstrated he has a far greater talent for than me!
                                    Below are some of my attempts so far with the last probably being the closest to what I'm after:
                                    Original fold as helpfully instructed by Gilles
                                    Scrunching of geometry at start of fold
                                    Scrunching at end of fold
                                    Getting there...but would rather the incline followed of at a tangent to folded curve...
                                    As close as I have got bending back the vertical portion from the specified point with a specified radius of 500mm - the distance from the horizontal to the vertical element
                                    My model file if tis any use?!
                                    No problem if nobody knows - this thread has already been a massive help to me so thanks!
                                    • gillesG Offline
                                      gilles
                                      Not sure to see what you want to draw, any reference pic even hand made?
                                      • panixiaP Online
                                        panixia
                                        in this particular case i would prefer "extrude edges by rails" from TIG extrusion tools.. actually i think is the more accurate and it also looks like the more "rhino-esque way"
                                          alcohorse
                                          Thanks Gilles. I don't actually have anything firther at the moment - the stair is envisaged as being part of a large mixed use building and is just a concept idea at present. Thanks for all ideas but the bending solution is definitely the best for what I need as it will transform the stair tread and glass handrails that will also be included.
                                          Obviously people will only be able to walk on the stair once the treads become fully horizontal I think I have all I need for now - I will probably post again when I am further along.
                                          Thanks everyone, and gilles in particualr for taking the time to label up your explanation.
                                          • gillesG Offline
                                            gilles
                                            You're welcome, don't forget to post your work on progress.
                                            • 1 / 2
