    So a quick ?
    layout
    5 Posts 3 Posters 706 Views 3 Watching
    • M
      mwm5053
      Can you combine two or more LO files into one, or can you combine two or more LO files to one PDF
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
        At this point the way to do that would be to create new pages in one file and copy the contents of pages from the other file to those new pages one at a time. There's no way in LO to use two LO files to create a single PDF but you could combine the two in Acrobat.
        • M
          mwm5053
          Thanks Dave much appreciate that.
          2011 iMac
          V2 Twilight
          • KrisidiousK
            Krisidious
            Well there is actually... It's called a scrapbook. Scrapbooks are layout files that are inserted into layout files. Although I don't think they update. for any referenced updating you would need to use a sketchup file inside of a layout file.
            By: Kristoff Rand
              Well, OK, you could do that.
              If you have SketchUp views in your LO project, you have at least one SKP file in the LO file.
