So a quick ?
layout
5 Posts 3 Posters 506 Views
    mwm5053
    Can you combine two or more LO files into one, or can you combine two or more LO files to one PDF
    2011 iMac
    SU 2015 Pro, 2017 Make
    V2 Twilight
    macOS Sierra 10.12.5
      At this point the way to do that would be to create new pages in one file and copy the contents of pages from the other file to those new pages one at a time. There's no way in LO to use two LO files to create a single PDF but you could combine the two in Acrobat.
        mwm5053
        Thanks Dave much appreciate that.
        2011 iMac
        V2 Twilight
          Krisidious
          Well there is actually... It's called a scrapbook. Scrapbooks are layout files that are inserted into layout files. Although I don't think they update. for any referenced updating you would need to use a sketchup file inside of a layout file.
          By: Kristoff Rand
            Well, OK, you could do that.
            If you have SketchUp views in your LO project, you have at least one SKP file in the LO file.
