    PNG transparency
    renderpluginsextensions
    3 Posts 2 Posters 393 Views 2 Watching
    • Z Offline
      Zylescozar19
      Goodafternoon!...
             Hello! My name is Zyl new here at SketchUcation I have question between this PNG file that i downloaded if you see attached you can see the png file not rendered has a transparent background. But then when i render it the transparent background of the png file becomes white or black something like that. How would i able to delete those unnecessary background color of png file when rendered (Easiest way)by the way im using SU 8 Pro Vray 1.48.89.
      Thank you so much for the help
      This community really great.
      Not rendered
      Rendered
        Tick the "Use color texture as transparency" in the Diffuse layer of the material.
        Ensure you keep your software up to date. That is an older version that will have more bugs than the latest version. The latest version is 1.49.01. It's something you should do when you start troubleshooting - some things can be the result of a bug which has been fixed.
        • Z Offline
          Zylescozar19
          woooooooooooooow!
          I finally did it.
          Thank you so much for the help Master Thomthom!!
          Thank you also for this great community...
          Render 1
          Render 2
