    SKETCHUP plugin to register an origins (axes)
    5 Posts 4 Posters 405 Views 4 Watching
    • P Offline
      pierro44
      Hello, I would like to know if there is a plugin to register an origins (axes) in dropdown menus like autocad, it will permit to save time for faires building facades, corners are not necessarily 90 °.
      thank you
        There are already the standard views...
        ...and Align View in the Context menu.
        Won't those work for you?
          I often set up Scenes which saves only the camera position. That let me quickly change axis.
          But after SU8 started to automatically adjust the model axis to the group/component axis I found that to work in 95% of the cases. (The rest I set up scenes for.)
          • P Offline
            pierro44
            Thanks for your answers
            • Didier BurD Offline
              Didier Bur
              You can also save a style with each of your axes settings, like so:
              DB
