SKETCHUP plugin to register an origins (axes)
Hello, I would like to know if there is a plugin to register an origins (axes) in dropdown menus like autocad, it will permit to save time for faires building facades, corners are not necessarily 90 °.
thank you
There are already the standard views...
...and Align View in the Context menu.
Won't those work for you?
I often set up Scenes which saves only the camera position. That let me quickly change axis.
But after SU8 started to automatically adjust the model axis to the group/component axis I found that to work in 95% of the cases. (The rest I set up scenes for.)
Thanks for your answers
You can also save a style with each of your axes settings, like so:
