    Need a little help to get started...
    3 Posts 2 Posters 818 Views 2 Watching
    • gascatG
      gascat
      Hi everyone.
      Well today is the day I decided I really need to learn to basics of DC's as I am helping a mate with his kitchen and he wants me to give him DXF files with cabinet parts (shapes of panels with drill marks on them)
      So I thought......What an easy way to introduce myself to DC's......FAIL !!
      As an example of what I set out to do....
      I created a small panel.
      I then created a 3mm crosshair to place on the panel. I want these marks to remail 25mm in from each end and one in the centre. I also want them to be 8mm up from the bottom.
      I set up two input boxes to set the size of the panel.
      Before I tried to add a formula to parametrically position these marks, I found that when I resized the panel the marks were squashing or stretching.
      Now I don't think I could have chosen a more simple thing to start learning DC's but I am stumped already and not being one for thinking like a programmer I will probably remain stumped!
      Can anyone help start me off with this as I have lots of drill mark options I need to explore but I just need to get through this first hurdle.
      cheers...Wayne
      • J
        Jim
        Hi Wayne,
        To keep the crosshairs from becoming distorted, you need to constrain their length and width. Do this by setting their LenX and LenY attributes to =3mm. (Assume you are working on the Red-Green plane.)
        If you change the origin of the crosshairs to be at their centers, this will make the position formulas simpler. (Assume you wll use 3 unique crosshair components.)
        With the origin at center, the middle crosshair can have a position of panelWidth / 2
        The left crosshair would have a position of =25mm, and the right a position of panelWidth - 25
        I've attached an example file - open it in SketchUp (rather than Import it in SketchUp.)
        I've shown a different technique for the crosshairs in the file. Instead of using 3 unique crosshar components, I use the Copies attribute to create the 2 extra copies (so there a 3 total crosshair components.) Then use some nested IF statements to set the crosshair position based on their Copy number.
        dc-panel.skp
        • gascatG
          gascat
          Thanks so much Jim. That gives me a simple insight and a kick start!
          I don't think I'll get into the if statements just yet but I will work toward it for sure.
          cheers...Wayne
